Computers & Internet Logo
Posted on May 12, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Unable to download to computer usb port does not recognize device I bought a digital concept card reader/writer the 21 in 1.I connected it to my computer with the usb hub the computer says it dose not recognize it what do I do?
  • MARY43BINGO May 12, 2008
    my hub is connected to my printer too. and it runs fine.
Anonymous
Level 3:
Genius:
  • Master 2,785 Answers
  • Posted on May 12, 2008
Anonymous
Master
Level 3:
Genius:
Answers
2785
Questions
Helped
860000
Points
7964
Scan for viruses first, then try the hub in another port then in another computer
  • Anonymous May 13, 2008
    have you tried the card reader in another pc
1helpful
Unable to download pictures through usb port
ALTERNATE WAY TO TRANSFER PHOTOS TO COMPUTER
If your photos are stored on the memory card, then remove the memory card from the camera and insert it into an USB memory card reader. Connect this USB memory card reader and memory card into the USB port of your working computer. Your computer will see this as an USB Mass Storage Device or an external storage device; you can then open the folder on the memory card and copy the photos to your computer. Memory card reader is a handy device and is inexpensive. You can copy photos from other cameras and you can also download photos off your memory card to someone else's computer without the need of installing any programs.
tip
How to Download Music to a Memory Card?
Downloading music onto memory cards allows you to conveniently transport and store your digital audio. Some personal computers come equipped with built-in memory card readers. However, external devices still provide download capability for those who do not own memory card-ready computers. In either case, the drag and drop process allows you to store your favorite music onto memory cards.
Instructions
  1. Insert the memory card into an external memory card reader or device associated with the memory card, such as a PDA.
  2. Connect the external memory card reader or device to your computer using a USB cable. Insert one end of the USB cable into the USB port on the external memory card reader or device. Insert the other end of the USB cable into the USB port on the computer.
  3. Wait for the computer to recognize the external memory card reader or device. You will access the external memory card reader or device as if it were a drive in your file manager. Skip Steps 1 through 3 and insert the memory card directly into your computer's built-in memory card reader if applicable.
  4. Open the file icon for the memory card reader or device to view its file contents as a folder.
  5. Open the folder containing the digital audio file you wish to download to the memory card.
  6. Drag and drop your desired digital audio file into the memory card reader or device's open file folder.
on Mar 12, 2011 • Cell Phones
PROBLEM WITH DIGITAL CONCEPTS SIM CARD READER CR-75P
If your photos are stored on the memory card, then removethe memory card from the camera and insert it into an USB memory card reader.Connect this USB memory card reader and memory card into the USB port of yourworking computer. Your computer will see this as an USB Mass Storage Device oran external storage device; you can then open the folder on the memory card andcopy the photos to your computer.A memory card reader is a handy device and are inexpensive.You can copy photos from other cameras and you can also download photos offyour memory card to someone else's computer without the need of installing anyprograms.
Apr 28, 2012 • Cameras
Sigma card reader/writer doesn't recognize my new SD card
What I suspect here is that, the USB port that you are using is a USB 1.0 port, which has a lower voltage not enough to power on your Storage drive.
In this case, there are two things you can do,
1. Change the USB port you are using for the storage drive to a USB 2.0 one (Just keep Checking all the ports one by one in case you dont know which one it is).
2. If your Storage drive has external power facility, just plug it in an external power first, before connecting it to the system.
If there are no USB 2.0 Ports on your system at all,
then just go to any electronic store and tell them you want to buy a USB 2.0 Expansion card.
and if it is a laptop, A USB 2.0 PCMCIA card.
Install it on your system, and connect your external drive through it.
Hope this helps you out.
Goodluck
2helpful
How do i upload picturs onto my computer
Your cam may have an option to connect using a cable.Most cams have a port on the camera that allows you to connect a cable and back into the usb port of the computer.And it appears on the computer as a memory device from which you can copy.In case your cam has a memory card .You can purchase a memory card reader which attaches to the usb port.The memory card can be inserted into the reader and photos copied from it.
2answers
My computer cannot find the driver for my Digital Concepts Card Reader/Writer Model CR-72. I cannot find anywhere that I can download the driver. It wsays that it is plug and Play. I found many sites that...
This is the vendor driver/support page for your unit. The only driver they have is for 98SE which usually means that the card reader should be plug n play in Windows. You may want to try the card reader in another usb slot and put a memory card into it so Windows can better identify it. Post your results back here.
Samsung s630
First, I need to ask the dumb questions:
1. Are both computers running XP?
2. When you connect the camera, do you turn the camera on?
3. Do other USB devices work when connected to the same
USB PORTS you are using to connect the camera?
Ok, since the camera is not recognized at all on both computers, we can pretty much disregard USB PORT failure, but just in case, try different USB PORTS on both, please.
Most if not all cameras should be recognized as mass storage devices just by connecting them to USB PORT on computer, and should be visible as a new drive in MY COMPUTER icon.
Maybe your bundled USB CABLE is not working, or this is one camera that insists on using the bunbled software package that came with the camera.
Last thing to try is to buy a multi-card reader/writer and put the memory card in there. That has to work!
Hope that helps.
1helpful
2answers
Sd card
have you try to insert it to another computer?
Computer recognizing device
Same thing happened to my Powersgot SD450. I'll tell you what the Best Buy Geek Squad guy told me: If it's off warranty, the repair will be about as much as a new camera. But, for $20, you can buy a USB memory card reader that will still read the card. I bought the card reader. It works great.
Grand Canyon Tech
Grand Canyon Tech
