SOURCE: can only use "Leap Into Learning" book. why not arthur,s lost puppy?
thanks for your concern. I called toysrus.
SOURCE: Leap frog globe pen no longer works
Either the wire is broken inside the insulation, or the batteries are dead.
SOURCE: Hello, When I touch the
Does the sound come at all ? if not then check the speaker inside orr the audio amplifier for failure. However if the sound comes on at start up then the screen should work even with the fingers, if not there is a possiblity of non conduction . Try to remove off the battery and reset. Hope this works. Good day
SOURCE: Leapfrog Leappad Learning System book. Regardless
Try cleaning the other cartridges contacts with alcohol and Q-tip. The major problem with the leappad is that the cartridges are failing after the warranty period is over.
SOURCE: It was working fine untill today now when i touch
have you had any luck with a solution I have the same problem, [email protected]
Given two sets S and T we declare S<T.if there is a mapping of T onto S but no mapping of S onto T is possible .prove that if S<T and T<U then S<U.
