Question about Sunbeam JARDEN FoodSaver V3840 Upright Vacuum T000 18001 T000 18001
FoodSaver v3825 (I believe it's the same as the v3840) will not pivot open so I can clean the drip tray - the release buttons are releasing, but it is hung up on something.
  • Mawk Oct 20, 2012
    Thanks, I had the same issue and your suggestion worked
Mine did that when I interrupted the cycle. I plugged it in and let the motor fully open the sealing chamber then I was able to pivot open the machine.
Posted on Oct 30, 2011
  • 1 more comment
  • Karen Shannon
    Karen Shannon Aug 22, 2013
    Thank you....I had tried just about everything and almost sent it to the Small Appliance Graveyard.
  • 1firebob Sep 07, 2013
    I can't get the unit to power back on? Any ideas?
  • Amy Dell
    Amy Dell Mar 01, 2014
    Thank you. That did it.
SOURCE:
How to clean drip tray on FSV12927
Contact Foodsaver to ask how to clean the drip tray.
http://www.foodsaver.com/service-and-support/service-and-support.html
At the web site shown above, an online chat person will appear and ask your name and information to help you.
Service Support FoodSaver
May 14, 2018 | Coffee Makers & Espresso Machines
Door to my foodsaver is stuck on one side. It's shut. How can I release it? Is there a release button anywhere?
Trouble with Food Saver Brand - Survival Podcast
thesurvivalpodcast.com > ... > Food Preps > Processing Food For Storage
Aug 15, 2010 - 17 posts - ‎13 authors
We have been using our Food Saver Vacuum sealer we bought ... connects somehow got stuck open and therefore the bags would not ..... I've had the FoodSaver V3840 for about 10 months now and thus far it has been great.Missing: door
FoodSaver Repair - YouTube
? 8:22
https://www.youtube.com/watch?v=jguFiF0Rouw
May 21, 2014 - Uploaded by Kelly Kimble
Repair a FoodSaver that isn't drawing out air anymore. In this case, its ... Vacuum Sealer Troubleshooting - Duration: 10:25. katzcradul 52,345 views. 10:25 ... How to Food Saver Lemon Juice or Other Liquids - Duration: 4:56.
[PDF]Use and Care Manual - Home Depot
Jan 25, 2016 | FoodSaver Vacuum Food Sealer - V3840
V3840 Food Saver won't vacumn
Hi valkenwil798
Go to the following webpage for parts to repair the vacuum part of the sealer
Please take time to rate me
Bud
http://www.foodsaver.com/parts.aspx?cid=0
Sep 30, 2012 | Tilia FoodSaver V2240
Why there say tray full red light
The tape trick didn't work for me. Had to cut the wires. Works for now.
Sep 27, 2012 | FoodSaver Smart Seal Vacuum Sealer V3825
The tray full light stays on even though the tray is empty.this prevent the foodsaver from operating.I have tried unplugging,recleaning the tray but nothing works
I had the save problem with my 3400 series.
The first time i was able to let it dry and it worked alright (48 hours).
The second time even this did not work.
If you remove the screws on the bottom of the unit. There are about 10 and pull it down, you will see the sealer assembly and a small circuit board in the middle.
Trace the wires from the drip tray, there are three of them, red white and brown, to the small white plastic JST connector on the small circuit board. Pull said connector gently to disconnect it.
The unit will function perfectly now, although it will no longer have a drip tray sensor of any sort it will function every time all the time.
All in all this took me about 10 minutes.
Thanks!
Sep 09, 2010 | Vacuums
Can't open my foodsaver for cleaning
I had the same problem and got this information from Foodsaver:
Turn Foodsaver unbit on and press the cabncel button. That should release the unit for cleaning.
It worked for me!
Feb 02, 2010 | Tilia Foodsaver V835 Vacuum Sealer
The Foodsaver V3460 will not open for cleaning. The left side appears to be releasing, but not the right. Your assitance is appreciated. Thanks, Steve
Just plug your unit back in and press the stop button, then it will release it automatically when you press the 2 green buttons, took a while for us to figure it out.
Oct 17, 2009 | Tilia Foodsaver V835 Vacuum Sealer
Foodsaver
Here is the link to your foodsaver manual.
http://www.foodsaver.com/Support.aspx?id=spma&mgid=1
Sep 09, 2009 | Vacuums
Sunbeam JARDEN FoodSaver V3840 Upright Vacuum T000 18001 T000 18001 Logo
900 people viewed this question
Top Sunbeam Kitchen Appliances - Others Experts
Irene Tulloch
Thomas Perkins
Thomas Perkins
Are you a Sunbeam Kitchen Appliances - Other Expert? Answer questions, earn points and help others
