HP Compaq Presario SR1500NX (PX786AA) PC Desktop Logo
Posted on Feb 01, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My compaq computer wont turn on for more than a second. It boots and the cpu fan starts but than the monitor doesnt show anything even though its on, the fan turns off and the computer stops booting. I have tried unplugging and plugging in all of the chips already but am not sure what to do now
Larry Ng
Level 3:
Top Expert:
  • HP Master 14,598 Answers
  • Posted on Feb 09, 2018
Larry Ng
HP Master
Level 3:
Top Expert:
Answers
14598
Questions
0
Helped
3278855
Points
66616
Its desktop clear as day.
does the pc run ok plugged it to another good working monitors
I see that relic monitor there, and I go , gee the CCLF tubes are dead,as all are now, used.
1 test and you learn what is bad, so easy, try a good monitor first.
then we work the end that is bad.
the only good clues are
1: fan runs in PC, both?
2: and no text ever (bad monitor)
Dabu42
Level 1:
Problem Solver:
  • Contributor 8 Answers
  • Posted on Feb 01, 2018
Dabu42
Contributor
Level 1:
Problem Solver:
Answers
8
Questions
0
Helped
2527
Points
27
1) Is this a laptop or a desktop?
2) What OS are you running?
3) When was the last time that it booted successfully? Did anything change then? Did you upgrade the OS? Did you upgrade the software (firmware) on the processor (Intel or AMD)?
4) Do you see anything on the screen? Compaq logo? Boot options?
3 Related Answers
Anonymous
  • 275 Answers
  • Posted on Feb 07, 2009
SOURCE: Monitor goes blank after seeing XP during boot up.
did u replace the video card with the same kind of model ? i guess yes ... when system starts hit the f8 key and than go in to safe mode ... mouse wont work so use arrow on the keyboard .. and in the safe mode just log in to admin account if available or login to ur account and see if that still happens .. and if it doesnt ... remove the drivers for the graphic card from add and remove programs and restart the system and go in the normal mode and than install the drivers again ... and if the display disappears in the safe mode or u have install a different graphic card than ... reseat the memory cards and that should resolve the issue .... if that doesnt work out when the system starts hit f1 and stay on the BIOS screen for 30 mins if the system doesnt loose display than u need to reinstall OS ... that will surely work out ... the resolutions given above if u follow them correctly u will have a working system in no time
Anonymous
  • 1768 Answers
  • Posted on Apr 06, 2010
SOURCE: powers up and cpu fan is racing but no boot,
This may be due to a CMOS mother board battery. I know that some tech or expert say that you can still boot without it but my experience is that if the CMOS battery is below 3.4 volts it may or may not post or boot. This battery is about the size of a quarter usually found at Walgreens or Walmart for about 3.00 dollars.
joecoolvette
joecoolvette
  • 5660 Answers
  • Posted on Jun 02, 2010
SOURCE: compaq presario sr2030nx won't boot. The fan
Bad Power Supply.
Weak Voltage power rail.
I'm going to explain what is wrong, and why.
Power Supply's are rated in Wattage.
The Power Supply used in a Compaq Presario SR2030NX desktop computer, is a 300 Watt unit.
(ATX style)
1) ALL the lights use Less than 1 Watt of power.
2) EACH fan uses 2 to 3 Watts.
3) A typical Processor uses 51 to 125 watts. Depends on what Processor it is.
The Compaq Presario SR2030NX uses an AMD Athlon 64 X2 3800+, processor,
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00754206&tmp_task=prodinfoCategory&lc=en&dlc=en&cc=us&lang=en&product=3245050
The AMD Athlon 64 X2 3800+ processor can use Up To 89 Watts, (Windsor Core)
http://en.wikipedia.org/wiki/List_of_amd_athlon_64_processors#.22Windsor.22_.28F2_.26_F3.2C_90_nm.29
(HP Support lists the Processor as an Athlon 64 (O) 3800+.
The (O) should be an X2)
This means your bad Power Supply has enough power to light lights, and spin fans, but not enough to turn the Processor on.
No Processor running, No computer.
Bad Voltage power rail.
Inside the Power Supply are Electrolytic Capacitors.
Electrolytic Capacitors can break down.
The capacitors are used as Filters.
They filter the incoming AC electricity (Input Stage), and the outgoing DC electricity made by the Power Supply. (Output Stage)
http://en.wikipedia.org/wiki/Switched-mode_power_supply
(Observe the photo to the upper right of the page. The photo can be enlarged by left-clicking on it. It can be enlarged twice)
Electrolytic Capacitor simplified construction:
The Electrolytic Capacitors used in the Power Supply, (And on the motherboard), of a Compaq Presario SR2030NX, are Aluminum Electrolytic Capacitors, which are of the Radial design.
http://en.wikipedia.org/wiki/Electrolytic_capacitor
Observe the two photos of capacitors, shown at the upper right of the page.
The Electrolytic Capacitor example shown at the bottom, of the bottom photo, is the Radial design.
(Short blue capacitor)
The case of the capacitor is an Aluminum 'can'.
Inside the aluminum can are three strips.
1) One strip is an aluminum foil, and is the Conducting strip.
2) One strip is an aluminum foil, and has a non-conducting medium applied to it.
This is the Non-Conducting strip.
3) The last strip is a paper-like medium, and is soaked with Electrolytic paste.
The paper strip soaked with Electrolytic paste, is placed in-between the Conducting, and Non-Conducting strips, and all three strips are rolled up tightly.
(The Positive lead of the capacitor is attached to the Conducting strip. The Negative lead is attached to the Non-Conducting strip)
When a capacitor breaks down the paste inside develops a gas. (Hydrogen gas)
This gas expands inside the case of the capacitor (Can)
At the bottom of the 'Can' is a seal. It is a synthetic rubber like material, and is shaped like a flat disk.
The top of the 'Can' has a shape etched part way into it.
The shape is commonly an X, or K.
When the gas expands, and develops enough pressure, either the seal at the bottom is compromised, And/Or the etched shape breaks open, to relieve the pressure.
The Electrolytic paste is pushed out.
So much paste loss, and the capacitor operates at a weakened state.
To much paste loss, and the capacitor fails.
A Capacitor as a electronic component that slowly develops a charge, then releases it all at once.
You may compare it to a large swimming pool being filled up by a garden hose, then one wall of the swimming pool is taken down all at once.
This is why the Power Supply worked when you unplugged it for a while, then plugged it back in.
The weakened capacitors paste chemical composition, allowed the capacitor/s to revert back to a working stage once power was removed.
(Power Supply unplugged from power)
When you plugged the Power Supply back into power, the capacitor/s were working again.
Worked with so much paste loss.
Eventually enough paste was pushed out, and the capacitor/s have failed.
What causes Power Supply failure?
1) The inside of the computer is dirty, as well as the inside of the Power Supply.
The cooling components of Power Supply is it's fan, and Heatsink's located inside the Power Supply.
[Refer back to the photo of the open Power Supply, in the SMPS link]
(A Heatsink is a component, that draws heat away from another component.
Typically, a Heatsink is composed of a flat metal plate, that has tall, thin fins protruding from it.
Heat is absorbed into the flat metal plate, whereby it is absorbed into the tall, thin fins.
The fins radiate the heat away.
When a fan is used in conjunction with a Heatsink, the air produced by the fan goes in-between, and around the fins, and helps carry heat away)
When the fan's blades, center hub, and surrounding cage are dirty, and the Heatsink/s are dirty, the cooling capacity drops tremendously.
Again, Heat = Wasted Energy.
The Power Supply tries to keep up with the call for power, and eventually components inside the Power Supply fail.
Electrolytic Capacitors are the weakest link, and typically fail first.
2) The computer manufacturer used a cheap quality Power Supply.
Cheap quality components used inside the Power Supply.
If you wish I can guide you in testing the Power Supply.
You'll need an inexpensive multimeter, or an inexpensive power supply tester.
(One example of an inexpensive power supply tester,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=5250576&CatId=5471 )
Or if you have a KNOWN to be good, compatible power supply, you can use it for a test unit.
Need help in finding a replacement Power Supply, or information in how to replace it, simply state so in a Comment.
My hpw1907 monitor says no input and wont display anything. The cpu also makes 1 beeping noise that last 1 second nd doesnt come back
A one second beep from the computer is standard for a proper boot.
Do you have a TV that you can plug your computer into to see if it is posting video? That would be the easiest way to test if it is a computer or monitor thing.
1helpful
I'm having problems with my compaq sr5000 desktop.
Is there any message that appears when you turn the computer on? Does anything post to the monitor during the boot process? Normally if the Video Card goes bad and the monitor works you will get a No Signal message on the Monitor. So you are so sure the monitor works, huh?
Since you went inside the computer check and make sure you pushed the Video Card (where the monitor plugs into the back of the computer) into the slot all the way.
Maybe your Power Supply is not working. When you press the power button do the fans start running and you hear the disk drive spinning? Just because you see a light at the the power button or on the motherboard does not mean the Power Supply is working correctly. I just changed one that did that.
Remove the Power Cord, Open the Case and remove one of thememory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x onit with an ink pen. If it fails to boot then move the chip to the nextmemory slot and try rebooting. If it fails take the chip out and set itaside, then put the other chip in and try booting it in both slots. If itboots, just to verify that the chip set aside is bad, mark an x on it and putit into the open memory chip slot and try booting.You didn't by chance remove the Heat Sink and CPU while you were removing the fan did you? If you did, you probably need to apply a fresh coat of Thermal Past between the Heat Sink and CPU.
Monitor goes blank and power light remains on and when i turn it back on, it stays on for about 3 seconds and goes blank again. thank you!
  • Turn on CPU.
  • CPU will be start booting. Red/yellow light will be blinking. If yes then check your monitor light will be fixing and Show *********** Board.
  • If shows and your OS will be Booting and fail to start.
  • If yes you can repair it.
  • Insert OS disk into the DVD driver.
  • Turn off PC.
  • Turn on
  • "Press any key........" when comes this message you press any key.
  • After that you can see two option
?? Fresh copy Installation OR
?? Repair Option
  • For Repair Press "R"
  • It will be start repairing
Thanks.
I've seen many others post this exact issue but there hasnt been any real solution that I can find. I have a DELL XPS Gen4 Pentium 4 3.6 GHz desktop. When I start the computer, the CPU fans go into...
I am having the exact same problem, but it only happens intermiddently. If I unplug the computer and then plug it back in it will ussually work for a while before it happens again.
I got a Compaq Presario SR1903wm .with red blinking light !!! power's up for about 20 seconds then shuts off !! doesnt even start up in Bios !! Dont know what to do !! should i replace the power supply...
check the ram memory ..if this shows up OK (verify it in another computer with the same specifications ) ...than the CPU is to blame ..open it up ..and remove for a few seconds the Bios battery to see if you messed up with the temperature settings ..This will reset to factory settings ..and if there is teh case with temperature limits too low set ..than it will power up after ..if it is the CPU you will have to change it
Computer powers up but wont display anything or respond to any buttons. HDD light flashes along with the CD drive. The problem started after holding down the power button for 5 seconds to do a emergency...
Weird though I dought that had anything to do with it. I would start by replacing the ram this will cause a no video boot as will a bad or overheated cpu. First b4 u spend money on the ram try hooking the external VGA output to another monitor see if u get boot screen. If not then start with the ram. If that doesnt fix it it may be a faulty motherboard which means time for a new laptop. Always get a shop to look at it b4 u trash though....
Acer Aspire 3100 Laptop Monitor will not turn on
Try Screen switch function to switch from Internal screen to External monitor to Both.
Normally FN + F4 (on Compaq or FN + F7 on Lenovo check the Function symbols on your Keyboard: allow few seconds after command to refresh configuration.
try Safe mode also. to check if display shows in VGA format.
Pc Seems to be dead wont load bios post moust doesnt work or keyboard or monitor
I have the same problem, the CPU fan spins, keyboard lights blink, no start up screen, or bios.
But, when I push a few times on the pc reset button, then the CPU fan is becoming still, the keyboard light are out and I can start the computer again in a normal way.
Can this one be a temporally solution for you too? Do you have any suggestion about?
I guess it can be an electricity dysfunction of a wrong fixed cable.
4answers
Thinkpad T20 no boot
TRY TO GO OLD SCHOOL AND USE A WIN 98 SART DISK OR TRY TAPPING F8 ALOT DURING START UP AND SELECT STEP BY STEP START
Emachines 1900+ gets power to the monitor and computer but wont boot
Buy a dianostics card, and find out if its the RAM, CPU, OR Motherboard. (sounds like a ram or CPU problem though) if you have more than one stick of ram in the system, take one out, and power it up, if still not response, to the other stick out, and put the stick you took out the first time, and put it back in.
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
