You have some good and bad information here NO Noise filter goes into the Coax line ever. The Noise filter goes into the DC power line feeding the radio. However it is best to determine what the noise source is and fix the problem. The part about unhooking the coax goes like this disconnect the coax does the noise go away? if it does NO Noise filter will help, instead fix the problem. if it is still there likely you can filter it out with a common DC Line filter available at most any good Car Stereo Shop. The closer the filter to the radio the better it works,
Where does the noise filter go? if it goes inline with the antenna, don't use it!!! It's bad for a cb radio.
The problem is that the V73 has a very sensitive receive. It is picking up noise in the car. Most likely the smog pump, or fuel pump.
Here are a few things you can try.
First, lets make sure where the noise is getting into the radio. It will either be getting in via the power wire, or the antenna.
To find out, here is what you do.
If when you take the antenna wire off the back of the radio, the noise goes away, then the noise is getting in via the antenna system. Solutions for this could be any of the following.
To find out if the noise is getting in from the coax, or antenna.
If the noise goes away, it is the antenna. Try a new antenna. If the noise doesn't go away, its most likely bad coax.
Now if when you disconnect the antenna wire, the noise is still there, then the noise is getting in through the power wire.
Here are some things you can do to get rid of the noise.
Some vehicles are noisy. You can't get away from it. Even with all of the solutions you may still have some noise. It's like that in my f150 pickup. I can't completely get rid of the noise, but most of it. In my blazer, I can hear the ignition noise if I do not use the ANL. In my friends dodge, he has no noise at all. Even without the ANL on. It's amazing.
