A lot of people will say that you need to peak and tune the radio to get more range. And it will, but what it really comes down to is your antenna system.
Even with the best peak and tune, if you don't have a good antenna system, it won't do you any good.
You need to make sure the antenna is a good match. If you don't know what that means, then you should refer to your manual on SWR. The antenna has to be tuned so that transmit power does not get reflected back into the radio. If that is happening, all of the RF power is not leaving the antenna, and you are not getting out as good as you can.
Once you have a good antenna system, then you can worry about peak and tuning. But for a peak and tune, I charge.
