Ok, if this is a heated tub then it is possible that it works off of 220-240 Volts AC. Either you have a disconnect close to or connected to the tub, or it may be wired directly to the main home panel. One side of the 220 volts circuit breaker may be tripped. (being that what makes up 220 volts is two lines of 120) Your circuit breaker may look like it is not in the tripped position, so shut off the circuit breakers then turn them back on again and see if that may have helped.
The breaker the manual is referring to will be the main circuit breaker at the panel.
If the system is not running the purge cycle as it is supposed to and turning the power on and off does not reset the control box then it is likely that the control box has a bad part in the circuity and should be replaced.
Hello, and thanks for the question. Your error code is actually "SN" not "5N" but they are sometimes difficult to discern on the LCD topside display. The SN error code is for a Non-functional High temperature sensor which automatically kicks the heater off and trips the breaker. You can purchase new sensors for $75-$85 (it could be more, my pricing index is quite a few years out of date) I'm not sure where the sensor is located in that particular tub, although it is most likely in the heating canister. Make sure the power is off at the breaker before attempting any tub repair. if you have shut-off valves to the heating canister you may not have to drain the tub, remove the heating can and replace the sensor you will have to plug/unplug the sensors from the power pack/circuit board. I hope this helps =)
F01 - There may be an internal problem with the control, attempt a Hard Reset.
Hard Reset - In some cases the control can be non-functioning or may not accept activation from the control panel. To clear and restart the control follow the these steps:
* Unplug or turn the circuit breaker off for 30 seconds. * Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet. * Press the Pause/Cancel/Stop button twice to clear the "PF" in the display. * Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts.
The F01 generally indicates a failed electronic machine control board. This error code can sometimes be caused by a glitch or power surge through the electrical lines. You may be able to clear this code by unplugging the washer for 5 minutes. If the code returns after plugging the washer back in, then the electronic machine control board will need to be replaced.
The procedure for accessing and replacing this control board is shown in this image...
Be sure to unplug the washer before accessing internal components. When you access the control board, I recommend transferring the wires from the old control board to the new replacement control board one connection at a time. Once you have all of the wires transferred, remove the old control board and mount the new control board in the washer. Reassemble and test the washer.
The "F01" error code indicates a communication error between the Central Control Unit (CCU) and the EEPROM onboard the CCU. The "F01" can also be displayed if the onboard "Pump Driver" fails to activate. Generally in order to correct this failure will require replacing the CCU. There is no way to test and verify if the control board has failed. The technical data sheet basically states to replace the CCU.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
you can also put a piece of paper between the ribbon cable where it joins up before the connector. It has been reported that the cable will short in this area. Try that before spending more money since most of the F-codes appear to be cable related.
check your power connections at the junction box, the unit for the clock is only pulling an amp at the most, but when you try to use the ove your putting the electrial connections under a load and if not tight or right will cut off the display and main cpu unit
there is a loose connection somewhere
