SOURCE: Problem with Audio on Handset
that mean you handset speaker have problem change the speaker or buy new phone for more happy moment
SOURCE: Can't deactivate headset
Did you check the connector on the bottom of your phone ? If theres any greenish stuff (oxidation) on the connectors/pins, there's your problem. This occurs if the connector has been exposed to moisture. If this is the case you can try to clean off as much as you can and it might correct the problem. But if this doesn´t work, the problem might be inside your phone. If you're up for it, you can take it apart yourself and try to clean the inside of your connector. If youre not up for it, or the connector is clean, take the phone down to your local service-center and have them take a look at it.
SOURCE: ear speaker not working on n95 8gig
If its under 14 days take back to the shop you got it from, if over then take to Nokia service centre to be fixed under warranty, if you bought from a someone and dont know what the state of play is with the warranty take to your local unlocking shop and they will fix it, I charge £15 in my shop to fix such a fault.
SOURCE: Nokia E90 Communicator - callers can hear me but I cannot hear
try to format your phone, and check if thhe problem persists.
FOR SOFT-RESET:
- at Standby Screen type-in => *#7780#
It will ask for “Restore all phone settings-phone’ll restart….”
Then it asks for security code enter factory default => 12345
FOR HARD-RESET:
- at Standby Screen type-in => *#7370#
FOR FLASHING- TOTAL RESTORE: (Do this if your phone does not boot up)
1) Remove the battery, and then wait for about 20 min or so before putting it back
2) Press and hold these three keys together -Green dial key, Star key[*], Three key [3]
3) switch ON the phone.
4) Do not let go the three keys until you see the WELCOME screen displayed and just let it complete the boot process.
check if this helps. if this doesnt help contact Nokia Care Point-> http://europe.nokia.com/A4388379
thanks for using FixYa
SOURCE: No tone unless speaker is used.
Have you changed the fasica? if so you may have disposed of the speaker as it sits in the old fasica
where the grill is
