F14 = EEPROM Error
The Central Control Unit (CCU) receives it's data from an EEPROM on board the CCU.
If there is an error reading this data, it will cause this error.
A power glitch may cause this error. Try unplugging the Unit for two minutes to see if that fixes the error.
Check CCU
So its likely you'll need a new CCU board. Check your owners manual, some models have up to a 5 yr. parts warranty on that CCU.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Hey friend, thanks for your post!
I see that your Electrolux wall oven is displaying an "F14" error code. "F14" stands for display tail missing, which means you could have an issue within your main control board or keypad. I would perform a reset on your appliance which can be done by flipping your household circuit breaker off for roughly ten minutes. If that does not correct the issue I would suggest seeking a professional to come out properly diagnose and repair your appliance. I hope this is helpful. -Matt
