Xerox CopyCentre C128 Black and White Copier Logo
Posted on Sep 03, 2010
Fault code 047-211 - Xerox CopyCentre C128 Black and White Copier
Xeroxrep
Level 1:
New Friend:
  • Contributor 33 Answers
  • Posted on Sep 08, 2010
Xeroxrep
Contributor
Level 1:
New Friend:
Answers
33
Questions
0
Helped
31870
Points
49
There is a loose connection on the finisher. The fault code does not appear if the copy/print is delivered to the middle tray I think.
The code means that the "offset catch tray home sensor did not turn on in specified time". You may manually move the offset mechanism and see if it moves smoothly.
JUMAAT BIN MAAMIN
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Oct 12, 2018
JUMAAT BIN MAAMIN
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
13788
Points
Hi there, how can i solve fuji xerox C5570 fault code E 047-211
Printer Xerox Docucolour 5000 with problem of error code, print engine subsystem fault 8-311 and other code of print engine subsystem fault 10-355.
You need a Service Call
Fault Code 10-355: A Hard Overheat Fault has been Detected in the Fuser Assembly. The Heat Roll Overheat Thermistor, the External Heat Roll Overheat Thermistor, and the Inlet Roll Control Thermistor all Indicate an Over Temperate Condition.
Aug 13, 2015
Fault Code 10-355: A Hard Overheat Fault has been Detected ...
https://www.support.xerox.com > en-us > article
Fault Code 08-311: Registration Side Shift Motor Fault
Aug 13, 2015 - Fault Code 08-311: Registration Side Shift Motor Fault. Article Id: 1088027 ' Published: 08/13/2015. Product support for.
Hi!Can you help me resolving error code 092-315 for xerox7225?
Can you verify the error code? 092-315 does not appear in the error code site. See link below
How To Search for a Fault Code WC7220 / WC7225 Fault Code Page
To search on a fault code, enter one code at a time. The codes will be displayed on the Touch Screen.
Fault code format: A 3-digit number, followed by a 3-digit number. For example, 010-352.
Viewing Fault and Alert Messages on the Control Panel
When a fault or alert condition occurs, a message will be displayed on the Control Panel to inform you of the problem. Alert messages inform you about printer conditions, such as low supplies or open doors, that require your attention. Fault messages warn you about printer conditions that prevent the printer from printing or degrade printing performance. If more than one condition occurs, only one displays on the Control Panel.
To view a complete list of active fault and alert messages:
  1. Press the [Machine Status] button on the Control Panel.
  2. Select the [Active Messages] tab.
  3. Use the Down arrow and select [Faults], [Alerts], or [Faults & Alerts].
  4. To view details, select a fault or alert.
Viewing the Fault History on the Control Panel
When faults occur, they are logged in to a fault history file by date, time, and fault code. Use this list to identify trends and resolve problems.
To view the fault history:
  3. Select [Fault History]. The screen displays the number, date, time, and image count for each fault code.
The following table represents the system area as represented by the first 3-digits of the fault code:
Chain Description 303 Communications Error 305 Duplex Automatic Document Feeder (DADF) 310 Fusing 312, 313 Finisher 371 - 375 Paper Tray Feed 377 Sensor / Interlock Fault 391 Drum Cartridge / Waste Toner
http://www.support.xerox.com/support/workcentre-7220-7225/support/enus.html
2answers
MY YBR ENGINE MANAGEMENT LIGHT FLASHES 3 SHORT FOLLOWED BY 3 FAST
That indicates fault code 33 which is a faulty ignition coil
Fault code 12 - Crankshaft position sensor
Fault code 13 - Intake air pressure sensor
Fault code 14 - Intake air pressure sensor
Fault code 15 - Throttle position sensor
Fault code 16 - TPS
Fault code 19 - No signal from ignition to ecu
Fault code 22 - Intake air temp sensor
Fault code 28 - Engine temp sensor
Fault code 30 - Tip over sensor
Fault code 33 - Igniton coil
Fault code 39 - Fuel injector
Fault code 41 - Tip over sensor
Fault code 44 - Read write error ECU
Fault code 46 - Power supply error to FI system
Fault code 50 - Ecu malfunction
How do I fix code 13 engine speed sensor Above 1000 rpm
Clearing the codes is simple that is done by removing the fuse of the EFI from junction box 2 for 10 seconds. Make sure to remove the jumper wire and switch the key off before clearing the codes.
Here are some common Lexus vehicles 1990-1995 codes:
Code 12 and Code 13 Rpm signal circuit fault
Code 14 Igniter signal circuit fault
Code 16 ECT control signal fault
Code 21 and Code 28 Main oxygen sensor fault (for ES300; SC300 & GS300 models)
Code 22 Coolant temperature circuit fault
Code 24 Intake temperature sensor circuit fault
Code 25 and Code 26 Air fuel ratio fault (for ES300 & SC300 models)
Code 27 Sub-oxygen sensor circuit fault (for ES300 CA & GS300 models)
Code 31 Low airflow meter voltage (for ES300 and GS300 models)
Code 32 High airflow meter voltage (for ES300 model)
Code 35 Barometric pressure sensor circuit fault (for GS300 & SC300 models)
Code 41 and Code 47 Throttle position sensor circuit fault
Code 42 Vehicle speed sensor circuit fault
Code 43 Starter signal
Code 51 Switch condition signal fault (for ES300; GS300 & SC300 models)
Code 52 Code 52 and Code 55 Knock sensor circuit fault
Code 71 EGR system circuit fault (for ES300; GS300 & SC300 models)
Code 78 Fuel pump control circuit fault (for GS300 & SC300 models)
6answers
Fault codes on a volvo FH12 rear left lights stay on
Volvo has had a lot of trouble with relays in the rear control module. Check/replace the relays for the rear lights with the updated relays.
7helpful
Trouble Codes
1. VW VAG type 5 digit fault code 19497 = EOBD type P3041 fault code:
Fault location = CAN data bus, instrumentation - implausible Engine Coolant Temperature (ECT) signal
Probable cause = Wiring, matching resistor in Engine Control Module (ECM)
2. VW VAG type 5 digit fault code 18032 = EOBD type P1624 fault code:
Fault location = Malfunction Indicator Lamp (MIL) - request signal active
Probable cause = Trouble code(s) stored in other system(s)
3. VW VAG type 5 digit fault code 01039:
Fault location = Coolant Temperature Sensor (G2)
Probable cause = Open or Short to Plus, Short to Ground - Intermittent
4. VW VAG type 5 digit fault code 01304:
Fault location = Radio
Probable cause = No Communication
5. EOBD type P0761 fault code:
Fault location = Shift Solenoid C
Probable cause = Performance or Stuck OFF
Top Xerox Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
