Is this the Problem???
Only Shortcuts,,,,,,
Don't format your Flash Drive.
Your data is still there.
Use Shortcut Virus Remover.
It will recover your all data.
DOWNLOAD !!!
http://www.svrtool.webs.com is changed, they have moved to a new home http://www.shortcutvirusremover.com
All files and folders have changed to shortcuts. Try to open (double click), nothing happen.
Use Shortcut Virus Remover, 100% free. Just double click the Shortcut Virus Remover. It will remove all shortcuts from your flash drive, external hard disk, recover all data.
Free download
Thanx
Shortcut Virus Remover works.
dooshnozzle spammer
doucebag, necro spamming SOB.
Shortcut Virus Remover realy worked.
direct download link - www.filesonic.com/file/825876924/SVRTool.exe
Download & Run Flash_Disinfector.exe:
http://download.bleepingcomputer.com/sUBs/Flash_Disinfector.exe
Shortcut Virus Remover is the solution.
REMOVE OR BYPASS THE SHORTCUT VIRUS USING THE FOLLOWING SIMPLE METHOD
http://619tips.blogspot.in/2013/04/shortcut-virus-removal-tool-and-bypass.html
When the shortcut virus infects a device, all saved files would become inaccessible. To access your files, you can remove the shortcut virus from your USB drive, pen drive, or SD card using cmd, shortcut virus removal tool and other manual methods. If the virus or removal process resulted in some data loss, you can get your files back with EaseUS data recovery software
How to remove shortcut virus from pen drive:
1. Go to Start and search for cmd. Right-click on cmd and click on "Run as administrator.
2. Navigate to you pen drive by typing drive letter, type E: and hit Enter. (Replace E: with the drive letter of your USB, pen drive.)
3. Type "del *. lnk "and hit Enter on your keyboard.
4. Now type "attrib -s -r -h *. * /s /d /l" and hit enter.
This page includes the complete solutions to remove shortcut virus from USB, SD card, pen drive, and even computer hard drive without losing data.
SOURCE: Due to virus folders in pen drive become shortcut
Why? Because that's what the virus is doing, maliciously.
Update your computer's anti-virus.
Or, better yet, UNINSTALL it (it may have been sabotaged/compromised) and install anti-virus software by downloading from: http://www.microsoft.com/security_essentials
Install this software. As the final step of the install, choose "full" anti-virus scan, and also select the drive-letter for your pen-drive, so that it also gets scanned for malware.
