Televison & Video Logo
Posted on Sep 03, 2010
I installed the FM transmitter module which came with my samsung LCD TV model LA40C530F 1R. I tried accessing the FM transmitter menu in order to turn the transmitter On and to set the frequency but that was not possible . How can I access this menu ?
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Feb 04, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
3115
Points
9
1. Press the menu button(green)
2. down arrow once - (a picture of a speaker should appear with sound written vertically next to it)
3. Right arrow once (selects the sound menu)
4. Down arrow till you see FM transmitter (down arrow 4 times on my TV. If you don't see the FM transmitter option in the menu then upgrade your TV to the latest software (details at the end of this help file)
5. Right arrow to get into the FM transmitter menu
6. select the "FM transmitter: off" line and turn it on (FM transmitter : on)
7. Change the frequency to to one that is not used by a radio station or has interference noise (get a radio and tune it till you hear the choosh sound with no beeping or clicking from lightning - then set the tv fm transmitter to that frequency using the up and down arrow keys and enter.
8. You should here your tv sound comming through the radio even if the tv sound is off.
If you need to upgrade your tv software then:
1. format a usb stick
2. download firmware.exe from"
http://www.samsung.com/za/consumer/tv-audio-video/television/lcd-tv/LA32C530F1RXXA/index.idx?pagetype=prd_detail&tab=support
3. click on firmware
4. click on "Upgrade File(USB type)" and download it to your usb stick
5. when the download is complete double click on the file and extract it to the usb stick.
6. eject the usb stick.
7. plug it into your TV and slelect software upgrade when prompted - I didn't loose any settings even though it warns you that you will (samsung are just covering themselves)
1helpful
2answers
I have a 2003 trailblazer and i bought a fob and it does not work after programing Everything thing works on my truck but the fob. Any ideas?
How was it programmed ? Was a scan tool used ?
Program All Key Fobs
To complete this programming operation, all keyless entry transmitters associated with the vehicle must be available for programming. Once placed into program mode, all previously programmed transmitters will be erased from memory upon the receipt of the programming signal from the first transmitter.
  1. Close the lift gate.
  2. Ignition ON, access the scan tool Lift gate Module Setup menu and select Program All Key Fobs.
  3. Follow the scan tool on screen instructions in order to program the transmitters. Select "Start" on the scan tool to enter the program mode.
  4. As each transmitter is successfully programmed, the scan tool will show how many transmitters have been placed into memory.
  5. When all transmitters are programmed, exit the program mode by selecting "Stop" on the scan tool. The vehicle will not respond to the transmitters until the program mode is exited.
  6. Operate the transmitter functions in order to verify correct system operation.
Program Individual Key Fob
If there are less than four keyless entry transmitters programmed to the vehicle, an individual fob transmitter can be added. This method will not erase previously programmed transmitters from memory.
  2. Ignition ON, access the scan tool Lift gate Module Setup menu and select Program Individual Key Fob.
  3. Select "Program additional Key Fob" on the scan tool.
  4. Follow the scan tool on screen instructions in order to program the transmitter.
  5. Operate the transmitter functions in order to verify correct system operation.
The FM function starts off great but loses reception after a couple of minutes and now the AM function has so much static you can not hear
AM FM TV Reception Guide and Directory » FM Reception ...
www.amfmreception.com/fm-radio/fm-reception-guide
Coax is a source of loss of signal from the FM antenna to the FM receiver and can also .... I believe the FM sound quality would strictly be a function of the tuner when ...It picks up the least off the side, but it does pick up some of the side. ...... THE ELECTRONICS so as not to short anything or to start the Great Chicago Fire of ...Missing: video
How to Avoid Distortion in Audio/Video Transmitters ' eBay
www.ebay.com > ... > Audio/Video Transmitters
An audio / video transmitter, or AV transmitter, is a wireless device that sends audioand ... As with all wireless signals, one can experience distortion or signal loss. ... AV signals are usually transmitted via wideband FM (frequency modulation) ... that of indoor transmitters, but the range drops off significantly the moment an ...
I have a 2004 GMC Envoy with 6 cyl engine. Both remote keyless entry went dead at same time and now I can't unlock the back hatch door. I had to release it manually but the sensor keeps locking it back....
Take it an have it check at a qualified repair shop for DTC'S - diagnostic trouble codes . Could have problem with the liftgate/endgate module. Don't try guessing to find a repair .
The keyless entry system has the following main components:
• The transmitters
• The endgate module (EGM) (XUV only)
• The liftgate module (LGM) (Except XUV)
When you press a button on a transmitter, the transmitter sends a signal to the liftgate module. The module interprets the signal and activates the requested function via a class 2 message over the serial data line.
Do you know what class 2 serial data communication network is ?
You need a scan tool to program the remotes .
Ignition ON, access the scan tool Liftgate Module Setup menu and select Program All Key Fobs.
Follow the the scan tool on screen instructions in order to program the transmitters. Select "Start" on the scan tool to enter the program mode.
012 GM Class II Communications
What or how do I install my Skyfi2 in my car without a tape deck?
Do you have a newer one (red and yellow box) or an older one (bubble box or white box?). If it says 'direct connect' in a reddish box it has a really cruddy FM modulator, if it is an older model from the clear plastic bubble box or white box, it has a really, really strong FM transmitter in it (so strong, the FCC outlawed it) and you can use it to transmit to an empty FM channel (within 50 feet of your radio!) So my answer is, simply go to the 'MENU" and under "FM Frequency" select an empty channel in your area, like 107.3MHZ and then set your car radio to 107.3 FM and it will come thru. You can also adjust the "Audio Level" in the MENU to make it even louder. Should work real well, Just check at the very ends of the FM band for channels first and try to set it 2 channels away from an active channel, so if you have a station on 106.5, you want to be on 106.9 or higher, etc.. Okay?
13helpful
3answers
I have a samsung TV that freezes temporarily.
i've just some digging around and found that you can access a service menu and perform a reset which sorted the issue for me.
Access the service menu by pressing, in order, whilst the tv is in stand-by mode:
info
menu
mute
power
when the tv comes back on you will have a service menu; select option 12 (reset) the tv will then switch off.
this will reset your TV back to factory defaults.
turn tv back on and you should be prompted to go through the plug and play setup again - go through everything and then all should start working OK
2answers
Trying to install Roady 2
If the Roady2 has a fm modulator built in, you can go to the menu and set the fm frequency. If it doesn't, you could use a fm transmitter that they have for mp3 players to listen to in the car
Not able to do fm transmittal
if the headsets work the fm transmitter may already be working. unless they are using an ir signal. you can test this by blocking the the ir or (infrared) led's on the lcd and the dvd player , if the headsets still work than its probably being sent via fm signal. turn your head unit on to fm andstart at 87.1mhz and work your way up to 89.9mhz in .1mhz intervals fm transmiters are usualy some where in that frequency.hope that helps
1helpful
2answers
STATIC/INTERFERENCE
&R=11812445&C=17577363&K=NBy0rr?h=2mv3s7&r=11812445 Your SIRIUS radio contains an FM transmitter that allows it to operate wirelessly through your car FM radio. We have determined that the output of this transmitter exceeds the limits established by the Federal Communications Commission (FCC). As a result, the unit may interfere with the performance of radios operating in areas adjacent to your radio. There are no health or safety concerns associated with this issue.
  • If you listen to your SIRIUS radio wirelessly through your vehicle's FM radio, then please review the solutions listed below and select the one that works best for you. SIRIUS will provide you the best solution at no cost.
  • If you use your SIRIUS radio only when docked in a boombox, or directly connected to your car radio or home stereo using audio cables or a cassette tape adapter, then no interference can occur and no further action is required, provided you have turned off your FM transmitter. To turn off the FM transmitter, first press the MENU button. Use the channel up/down buttons to highlight “FM Transmitter” and push the SELECT button. Use the channel up/down buttons to highlight the "FM On/Off" menu item and then press the SELECT button. Use the up/down buttons to highlight "FM Off" and press the SELECT button. To exit the "FM On/Off" menu, press the MENU button. Use the same procedure to turn off the FM transmitter if you use Solution 1 or Solution 2 below..
Solution 1 - Direct Wired Audio Connection: If your vehicle radio has a “LINE IN” or “AUX IN” jack, you can use a stereo cable to connect directly to your SIRIUS radio. This solution is the easiest to install and provides the best audio performance. Many newer vehicles provide the required audio input jack. It will normally be found on or near the front faceplate of your vehicle’s radio.
Solution 2 - Cassette Tape Adapter
: If your vehicle has a cassette tape player, you can use a cassette adapter that allows you to play your SIRIUS radio through the cassette portion of your vehicle radio. The adapter slips into your vehicle radio as easily as a cassette tape and provides better performance than a wireless connection. fcc_a_2.jpg
Solution 3 - FM Extender Cable Kit: An FM extender cable will provide a special transmitter antenna that allows you to obtain the best audio performance through your vehicle’s FM radio. This solution is easy to self-install, but does require that an easy-to-hide wire be run in your vehicle so the transmitter antenna can be placed in close proximity to your vehicle’s radio antenna. Using this FM Extender Cable Kit, you will continue to use your SIRIUS radio exactly the same way as you do currently. fcc_a_3.jpg
Solution 4 - FM Direct Adapter with Professional Installation: An FM Direct Adapter provides a wired connection between your SIRIUS radio and your vehicle’s radio. You will continue to listen to your SIRIUS radio through the FM tuner of your car radio, but the FM Direct Adapter eliminates the outside static and interference you sometimes experience when using a wireless FM connection. This solution usually requires professional installation. We will provide a certificate redeemable for installation at an installation center in your area.
Please go to www.sirius.com/optimize and select the solution that works best for you. If you have any questions, please call 1-(877) 635-5130. Detailed instructions will be included with your solution.
You will improve the performance of your SIRIUS radio and reduce the potential for interfering with adjacent radios if you properly tune your FM transmitter. Please see the FM Transmitter Set-Up Tips below for more information.
We are sorry for this inconvenience. We are confident these solutions will allow you to continue to enjoy the great music, news, sports and entertainment that only SIRIUS Satellite Radio can offer with no impact on your radio’s performance.
Sincerely,
SIRIUS SATELLITE RADIO
To tune your FM transmitter turn off your SIRIUS radio and tune through the FM channels on your vehicle’s radio to locate an FM channel (except 87.7/87.9) that is not broadcasting in your area. If you use an FM channel that is being used by a local broadcaster, it will interfere with the performance of your SIRIUS radio. Once you have located an FM channel that is not being used for broadcasting in your area, save it as a preset on your vehicle radio. This will become your SIRIUS preset. If you’re not sure which FM channels are not being used in your home or travel cities, you can go to www.sirius.com/fmchannel and search for an FM channel based on zip code.
Turn on your SIRIUS radio. In the SETTINGS or MENU on your SIRIUS radio, locate the “FM Frequency” adjustments. Set the channel number on your SIRIUS radio to match the SIRIUS preset on your vehicle radio. Refer to your user guide for detailed instructions on how to do this. The FM transmitter in your SIRIUS radio is automatically set to FM channel 88.1. This may not be the best channel in your area.
11helpful
Samsung LCD Tv
Try this:
Access menu service by press on your command, with your TV OFF:
INFO + MENU + MUTE + POWER ON
Then you should get access to Service Menu.
The last item says: RESET
This will do a reset to the TV.
Make no harm.
WARNING: If when on service menu you feel tempted to "screw" on anything FIRST take note on ALL you change! You can compromise the TV ...
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
