Hi i have the above LG Dishwasher and a couple of minutes into the cicle 03 error comes up on the display screen. Could you please help as I have no manual. Thanks
Hi
OE in your dishwasher is a
drain error and dishwasher not draining issue usually occurs due to kinked
drain pipe, clogged drain filter or drain pump. First make sure that the drain
is not clogged and remove clogs if present. If no visible lint is present then
remove the lower front access panel to check the drain filter and drain pump
for any clogs, you'll need to clean the drain filter and drain pump completely.
Also, check for any food pieces stuck near the pump impeller & clean the
chopper assembly. If the issue
returns after cleaning then the drain pump assembly should be replaced. Hope
this helps...please post back for further assistance.
Daniel
Hi
Error
code IE on LG dishwasher means Inlet error. This error comes up when the Water
Supply Tap is closed or Water Supply is shut off. If water supply is turned on
then make sure that the Inlet Hose is not kinked and water Pressure is not low
(should be above 10 psi). Next thing to check for is Water Inlet Valve, measure
the electric resistance of Inlet Valve. (950-1300 ohms) Make sure the filter of
Inlet Valve is not clogged.
Hope this helps... Please post back
Daniel
After the dishwasher runs for a few minutes code 0E appears. i saw it is a drain problem. should i pull the bottom grate and see if there is an obstruction. any advive would be helpful, thanks Jim
O3 is not a recognized error code. Is it possible that the error code is OE. That is a drain error problem. Is there water still in the tub??
