NorStar M7310 Corded Phone Logo
Anonymous Posted on Sep 02, 2010
I used feature 983 to delete a few old mailboxes. Once I completed that, I no longer had access to features 983 or 981, because it is now telling me that my passwords are incorrect. How do I reset these features and passwords?
  • Anonymous Sep 07, 2010
    sorry i postded incorrect info... I actually need help with programming the voice mail feature 981(not 986) programming and accessing the general admin's voicemail.
george peters
Level 3:
President:
  • NorStar Master 860 Answers
  • Posted on Sep 02, 2010
george  peters
NorStar Master
Level 3:
President:
Answers
860
Questions
0
Helped
609277
Points
3471
It sounds like you've either deleted your own mailbox or reset the password to 0000 and changed the password to the administrator mailbox. To reset the administrator pasword enter feature 985 press 9, at the password prompt enter 73738767793 (resetsmpwsd) and press ok or #,press yes to reset password. password should be defaulted to 0000. then try Feature 983. if your system has 2 digit intercom #s your password is 120000. 1020000 if you have 3 digit intercom numbers. Once that's done you can go into admin programming to default your password back to 0000.
Testimonial: "perfect consultel1.... your advise was right on the money and i didn't even have to try twice:) but now how do i set up the general voice mailbox to work with "Feature 986" all other extensions seem to be working fine. What should my service class be? "
  • 4 more comments
  • george  peters
    george peters Sep 07, 2010
    Feature 986 is the transfer to mailbox function. Is the problem with transferring to the generial delivery mailbox?
  • george  peters
    george peters Sep 08, 2010
    ok, to program a button for voice mail press feature *3, then the button you wish to be the open voice mail key. and press feature 981. As far as accessing the generial delivery mailbox, using the open voicemail key on the extension you programmed to recieve the generial delivery messagesshould get you there but, if you wish to access the generial delivery mailbox from any other set you can press your open mailbox key, press the OTHR soft key and enter in the generial delivery mailbox number and password (100xxxx, ok),
  • george  peters
    also the class of service shouldn't matter too much for the general delivery. I usually use COS 3 because it has a decent message length time and a password expiree of 90 days.
  • Jrevangelist Sep 16, 2010
    How do I find feature 985 or 983. I have Nortel networks T7316E, when I press on Voice Mail button(3rd from bottom left)it displays feature 981 and then asks me to enter password. I had reset the password to 0000 a while back(don;t remember how) and now it says mailbox locked, contact admin....Help Please!
  • elise Dec 13, 2012
    it was right on the money!!!! i was getting so frustrated and im so lucky i found ur solution... Thank you so much !!!!
How do I toggle between day greeting and night greeting? Our s seems to be stuck on night and I don't know how to switch it back/toggle it. Just started at this company and no one knows how to use the...
Night feature at reception set or set that you put night service on go Feature #87. For delete of mailbox Feature 983 enter password which should be 1020000 if 3 digit extension numbers or 120000 if 2 digit extensions. Then press mbox then del enter extension number then press del.
Unable to access voicemail feature inactive
This means the system can no longer communicate with the voice mail. You can try to locate the voice mail and power cycle the unit to resolve the issue, If you still get inactive feature after the reboot you will need to replace the vms.
1helpful
3answers
My MBOX is locked on my T7316E Nortel phone. Also, trying to retrieve messages from home I somehow changed the password and I don't know what it is.
Feature 983 log in is 120000 (if 2 digit extension, 1020000 if 3 digit, 10020000 if 4 digit extensions)
Select Mbox, enter that locked extensions mail box number, You will see password RESET. Select RESET. Release out. This will reset that mail box password to 0000. Use feature 981 on that phone and enter the new default password of 0000. you will then be prompted to change the password.
Feature 985 will show you your mailbox extension
2helpful
Mbox Locked - Feature 981
Feature 985 is used for resetting the administrator password.To reset a subscriber mailbox press feature 983, enter in log (default 1020000), on the 3 soft keys bolow the the screen press mbox,chng, enter extension number of the locked mailbox, press reset at the reset password prompt.press rls key
2answers
I have tried feature 981, 982, 983 etc. and I get the message "Inactive feature". What is the problem.
First make sure u r using Voicemail system which is either Star talk or call pilot.
If u r any one of this then only u can use F 981, 982 , 983 or 985. Its a feature code of voice mail.
If u r using either of this and still gettin inactive feature, then try with rebooting The Satr talk or call pilot i.e. switch off from mains wait for few mins and switch it back on.
After rebooting it will take 15-20 mins to boot up the system and after that u can use these feature.
Thanks.
Abhi
Also trying to initialize voicemail, says Feature 983 inactive
Feature 983 gives cess to System Administration; This Feature will ask for a Log:
Feature 981 Opens A Mailbox your mailbox # should consist of three digits. First what is the name of your mailbox system?
Log #
If you are not the System Administrator/Coordinator, your phone doe not have this privilege.
Please use the Feature 981 enter your password. You really should ask your Administrator to delete your mailbox and re-add it.
2helpful
2answers
Lost voicemail on phone system Norstar T7316E
So, voicemail does not pick up or answer at all?
80helpful
6answers
Nortel T7316E
To reset passwords for Feature 983 do the following
Press Feature 985
Press 9
Enter 73738767793
Press OK
Now go back to Feature 983
Enter 120000 for 2-digit extensions, 1020000 for 3-digit or 10020000 for 4-digit
Top NorStar Lands Phones Experts
Paul Bade
Daniel Blask
Daniel Blask
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
