Have a Maytag dishwaher model number MDBH970AWQ, it is leaking a lot of water underneath have tried to locate the leak but can not find it, can tou help?.
During defrost it is normal to get water to collect and evaporate. If you are getting a lot of water where it is overflowing, the solenoid water control valve is leaking by and needs replacing. They can be obtained for your refrigerator by enterring your model number on Searspartsdirect.com.
it could be coming from different sources. Most likely is the hose. You might need to replace hoses that bring water to the machine, but first check that they are not loose or have cracks that could cause these leaks to occur.
slide a piece of paper under the unit when the floor is dry, fill some water and peer underneath the unit, when you notice water drops this location will indicate your leek location, lay unit on its side and track down the leek
My Maytag washer model #:sav515deww is leaking underneath during the spin cycle. I took off the 2 front panels. I have been told taht it is a bearing and a seal that are out. Replacement parts cost approx $90.00. Unit is 5 years old. Is it hard to fix? Thanks
if the dishwasher is leaking water there is no recall on that. the recall i believe you are talking about would be for the rinse aide leaking in the door. you should contact maytag to see about getting the new kit installed on your dishwasher and you may get your leak fixed for free since the kit comes with the door seal. You can contact maytag at (800) 675-0535 do not wait and do not use the dishwasher. you will need the model number and serial number off your machine when you call. it is located near the door seal on the tub.
I'm dealing with the same problem right now with the same refrigerator. The cold water tank (for the front dispenser) has a hole in it that leaks every time someone dispenses water from the front door. You will find the water tank behind the top slide-out drawer in the fridge. The leaked water flows down one of the water tubes through a hole in the bottom of the fridge and onto the floor. I'll bet you have the same problem. Good Luck.
