Nokia N72 Cellular Phone Logo
Posted on May 10, 2008
N72 Backlight Hi, The backlight of my phone is not turning on. It just blinked 2-3 times yest and then went off. N since then my poor phone is in complete darkness. Solutions Plz!!!!!!!!!
Anonymous
Level 1:
  • Contributor 20 Answers
  • Posted on Jul 05, 2008
Anonymous
Contributor
Level 1:
Answers
20
Questions
0
Helped
5887
Points
44
In your settings, choose display option and make sure you have it set to the setting you prefer. if you still have a problem, do a hard reset by removing the battery while the phone is still powered on. leave battery out for about 3 seconds, then replace and power back on. If problem persists after that, you will need to contact ur customer support to determine your software version for your device. if all else fails, a master reset could be tried.
2answers
Is there a way to enable the backlight to turn on each time a button is pressed on the ur5u-8780l remote and the rc122 remote.
if you don't see any button with bulb icons on the remotes, then I would use the table of contents of each remote manual in order to attempt to get the backlight activated when click the remote buttons.
Thank you.
2helpful
4answers
Blink codes for a 58 Hisense TV
The back light and the LED and the screen went bad and should be replaced.
Klv32s310A sony bravia gets start on with green light and after a second turns to stand by mode blinking the red light 6 times after each 2 second interval
Hello Sagar,
green led means tv powered on and status ok.
Red blinking light almost always means defect, overcurrent or overload.
6 blinks for Sony lcd flat tv means trouble in backlight circuit, or backlight inverter (backlight illumination or lighting makes your tv screen visible).
common problems in the inverter circuit, which drives the backlight, or shorted drivers, or short-circuit transformers or open circuits.
You should find the problem in the inverter circuit, or in the power supply board or in the main board.
Also look for bad capacitors (electrolytic caps) which are bulged and swollen on top.
Decoupling plugs from printed circuit boards can help you in finding the problem board by elimination method.
If you power up the set after unplugging certain plugs on f.e. the inverter board , this could result in getting a green power led and concluding that this board is faulty.
succes,
Walter from Antwerp, Belgium.
3helpful
2answers
Samsung 32'' LCD TV backlight works occasionally
Check for any loose soder points or loose connections with wiring sockets to backlight inverter board.
Acer Aspire 5610 LCD backlight problem
my laptop is acer extensa 4620 problem is web cam is not working what will do
If it is less than 1 year old, go to http://www.acerwarranty.co.uk for UK or http://support.acer.com/ for US.
I did this last year for my girlfriends laptop backlight problem and it was a free courier both ways and was repaired within 2 weeks (new part required). No cost to you.
Otherwise, sorry I dont know how to fix it.
3answers
Backlight went out
the HTC needs to be reflash to correct this issue...so take the phone to a mobile service center to have that done or try sourcing it online.
No backlight
Have you checked your settings? Maybe you accidentally, or unknowingly turned off the lighting.
Please rate fixya!
Backlight
Hi Em,
You wanted to turn off permanently the backlighting on your IPod Nano? Your player uses that backlighting in order for users to see the display during poor lighting conditions.
If you really wanted to switch it off, you can access the backlighting settings on your player; Select Setting then go to Backlight Timer, Choose the option that suite your need
(Always On, Off, Turn off after a period of time between 2 and 20 seconds) or you can press and hold the Menu button down to toggle the backlight on your player to on or off.
Backlight problem
exchange the phone for a new one.........see if that corrects the issue
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
