I bought Sandisk 2 GB pendrive 2 monts ago & now its not working. Its not detected. When i see through disk management, i can see the drive with no media. When i see its properties, and the volume option, i can see:
Status: No media
Partition type: Master Boot Record
Capacity: 0MB
Unallocated space :0 MB
Reserved space : 0MB
I dont know how to overcome this problem.
please kindly help me........
click start control panel administrive tools ,computer management ,device manager scroll down universal serial bus controllers you should see a yellow question mark? right click to reinstall drivers or if you can see your usb but its not working ports(com&lpt)right click update driver then click start click on my computer you should see your pen drive right click then select format another way is to control panel administrive tools,computer management disk management right click on your drive select format hope this helps
you may need some USB drivers for this particular pendrive control panel admistrive tools,computer management,device manager you should see a yellow question mark? right click to reinstall drivers hope this helps
I have experienced this type of problem before. But what I did was to install an Avira Anti-virus on a system using windows xp and eventually it did open.
So you can try it as well or insert your flash into any another system that had a strong anti-virus which can enable you scan/format the drive.
Assuming that you are using windows, go to drive management and see if the pendrive is detected. If so, right-click on it and format it. Or look for the HP USB Disk Storage Format Tool and use it.
You can try using another usb port, or it might be that other things conncected to the usb are interfering with it. Try disconnecting things attatched to other usb ports (check in the back of the computer) but be sure that they're not important before you go ripping out cords.
first insert your sandisk pendrive.Now right click on my computer.Go to manage option . select disk management. From that you must select your drive letter for your pen drive.Go to Action menu near to File menu.Fromthat select all tasks and select formatting.Then again goto all tasks and select change drive letter and paths.select the drive letter and your problem is solved. thanks for asking your problem.
