Question about Nokia N95 Cellular Phone
HOW do i change the LCD on the nokia n95
How do i change the lcd on the n95, as a good member told me when i asked him the question, how do i fix my phone when the screen doesnt light up, he replied that i should change the lcd , how do i do this ?
plz i really need all the help i can get, thank you for reading
  • 242 Answers
Here is a video which explains how to replace the screen, pretty clear.
Hope this helps
Posted on May 10, 2008
    New Friend:
The basic process requirements of the surface SMT for new FPC and the traditional hard board PCB are quite different. They are both well positioned. Mainly because of its soft board, FPC demands an inclusive loadboard to finish the fixing and tansfering and other SMT technological process. products from xinda international
Posted on Mar 06, 2014
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Nokia Master
  • 545 Answers
Posted on Mar 10, 2015
    Filmmaker:
    Uploaded 5 video answers.
  • 139 Answers
Go to this link:
http://youtu.be/fNEOaB-mlSI
Posted on Nov 30, 2014
  • Sanjiv Sharma
    Sanjiv Sharma Mar 17, 2015
    before changing LCD first be sure that is it the backlight of the screen that is not comming or it is the image on screen thats not comming......if image is visible but it is too dark...then it is possible that there is somethging arong with the light section of your mobile............/if there is no image and no backlight, before disassembling your phone.....first insert sim and bee sure that your phone recieves a call.....if calling is OK....then change the screen.......if calling fails then somethings wrong with the processor or software if your phone>>
    New Friend:
    Problem Solver:
  • 11 Answers
The LCD is attached to the board with a frame. The frame is attached to the board by two clamps and the connection cable from LCD to the board. The cable is covered by a hood that is also fused with a clamp to the board.
Step by step.
1. loosen the clamps on the sides of the board
2. remove the frame by lifting it up and pull them over the side of the board (upwards)
3. remove the upper cap that holds the connection LCD-board
4. lift up the LCD and unplug the connection from the board. It should be easy, but if not use carefully some more strength. Get it Repaired Ltd
Posted on Nov 19, 2014
    New Friend:
  • 3 Answers
Just go to the market and fix it out.
Posted on Sep 04, 2014
SOURCE:
My LCD not showing anything just blank and light
if the lcd and ribbon are seperate, then pls check the connections, if ok then its goof. However, if it does nolve the probelem, it is better to try new lcd and ribbon...to know which one is deffective.
May 30, 2009 | Nokia N95 Cellular Phone
I have a Nokia N95 8gb and in anger threw it across the room. Its is now well and truly broken. I have experiance with repairs, so have tried to repair it myself. I fixed the slider problem but on power...
You can find replacement LCD screens for N95 in this link. There is also a video explaining the installation:
http://www.pantallas.biz/epages/wwwpantallasbiz.sf/en_GB/?ObjectPath=/Shops/160419/Products/N95
Note that N95 and N95-8GB have different LCD screens.
I hope it helps.
Ignacio del Olmo
May 30, 2009 | Nokia N95 Smartphone
Nokia n95 8gb lcd is blank but i hear it's turning on
if its blank you have to replace the lcd screen with a new one.
sometimes it maybe a flex cable problem which occurs in some slide phones.
at mobile phone repair stores, the cost of an original lcd screen replacement is usually $150-$200, though sometimes an original lcd screen may not be fitted into your device but rather a hong-kong made one which is similar to the original but is less brighter and a little less sharper.
if you take it to a nokia care centre to replace the lcd screen you may have to pay over $250.
you can just buy an lcd screen off ebay, replacing the lcd screen yourself isnt hard with the tools provided. you just have to take the ribbon cable from the old lcd screen and insert the new lcd screen and plug in the ribbon cable for it.
the reason for original Nokia n95 8Gb lcd screens being so expensive to repair/replace is that it is also the same lcd screen used for the Nokia N96.
cheers.
I have dropped my nokia n95 phone and the lcd screen broke. how can i fix this and how much will it cost?
HI,
you can go to a service center to ask them for a replacement of your LCD.
but i do not have any idea how much it will cost it will base to the service technician.
i prefer to advice you that go 2 or 3 more service center to ask the prize and the cheaper price will left you can buy it.
thanks,
May 07, 2009 | Nokia N95 Cellular Phone
Nokia n95 8gb blank screen
hi the main problem is not in ur display screen. the lcd is ok. but inner connections might have got damaged.
Jan 19, 2009 | Nokia N95 Cellular Phone
Backlight on the screen not working
there is dim light on the screne
Nov 12, 2008 | Nokia N95 Cellular Phone
Nokia n95 screen doesn't work
please check the ribbon,from the board to lcd.go to the certified technician.
Oct 30, 2008 | Nokia N95 Cellular Phone
Nokia N95 Cellular Phone Logo
368,807 people viewed this question
Top Nokia Cell Phones Experts
jonathan mariano
jonathan mariano
Damen Wong
Damen Wong
