We have been using the beko 510 for 18 mouths with no problems, and for some reason now it leaves clothes soaking wet and sometimes unrinsed. it doesnt seem to do the rapid final spin at the end either on normal wash setting or just spin and drain. there was a kink in the outlet pipe thae i have now removed but it still does it.
the manual talks about adjusting settings during a wash if you pause, but says nothing else about how.
please can you help.
many thanks
rowan
Find out where your filter is & clean it out thoroughly, refit.
Wil see to it in 24 hrs
Check your exit hose spigot, it may be clogged. This is if your filter is all clean (ref manual). There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
If the exit filters are clean & you still have the drainage problem it has to be something clogging your pump, have to dismantle it to examine. Something must be blocking the impeller to prevent pumping. Be prepared for a lot of water coming out when you do the job.
"jsrock516" has a solution for Kenmores, it could help.
1. Unplug machine.
2. Remove the lower kick plate under the door. There will be a
screw in the bottom corners of the panel holding it on.
3. Find the drain pump. It will be on the right-hand side and is
usually white in color. The drain hose from the bottom of the
tub will be connected to it.
4. Remove drain hose from standpipe and connect a wet/dry
shop vac (if you have one) to the end of it.
5. Turn vacuum on and watch the drain hoses from the tub and
from the pump. If the hoses collapse, you have a clog
somewhere.
6. Remove the drain hose leading to the pump. Check the
impeller area of the pump for debris. This is usually where
coins, clothing labels and other items get caught.
7. Clean out the pump and drain hoses.
8. When finished, reconnect any drain hoses that you previously
removed making sure you get a good seal with the hose clamp
BEFORE you fill the machine. If you notice a leak during fill, hit
the "CANCEL" button to stop. Make sure you place the drain
hose back in the standpipe too.
Our Beko 510WMA stopped draining and spinning. I tipped it up, removed the pump and checked the hose btn the drum and the pump. There was a sock in it! The machine now works but, alas, the sock had to be thrown away....
I have a whirpool washing machine. The model # is A7680t. It does not spin fast enough to get the water out. If some of the cloths are taken out ,then it spins faster. It is a top loading machine. I was looking at a major repair manual and they have type I and Type II washers. I am not sure what mine would be. I need help.
Thank You:
Gene:
thankyou for your help, i have already done that, the washing is comming out smelling like dirty water, do you think it could be the pump blocked?
the machine won't do the final spin, clothes are soaking.
They are thoroughly washed but not spinning on any cycle.
Filter is clean.
help!!
same machine and problem here
no final spin
clothes are wet
and the filter is clean hm
Yes, we do. Our BEKO 510W also takes ages to go through a cycle and doesn't go for the final spin. Has anyone go a fix for this yet? It's costing us money, time and effort. The clothes can't be hung up in the flat, that's for sure
D
i seem to have the same prob with my beko washing machine..sometime it spins and other times like a granny trying to cross the road.,..no final spin
