Ok, thanks for the clarification. Even though the cord
doesn't have any external damage, it's still very possible that it has gone bad. When a
Sebo upright
doesn't even start, this can mean one of several things. The parts that could go bad that would cause the machine not to turn on would be the cord (most common on a
Sebo), the on/off switch, the PC board that's on top of the motor, or the actual motor. In the 7 years that I'
ve been selling
Sebo, I have only changed out one PC board, and I'
ve never had to replace a single motor on a
Sebo yet. I have had to replace several cords over the years, some showing external damage, others
didn't show any damage.
The cord and the switch are going to be the easiest parts to test, and also happen to be the most common, so this is a great place to start.
Here's how you can test the switch and the cord on the vacuum cleaner. You'll need to have a simply Electrical tester that will test if current is going through the cord. Here's a link to a similar one that is very inexpensive that I used in this repair solution:
http://www.homedepot.com/h_d1/N-5yc1vZ1xh7/R-100183054/h_d2/ProductDisplay?langId=-1&storeId=10051&catalogId=10053
Step 1. Unwrap the electrical cord from the vacuum cleaner, and set the entire cord aside. Also remove the on-board wand that rests directly behind the bag housing. After the wand has been taken out, you should see on the left side of the vacuum where the handle goes into the body of the vacuum a little gray lever (my picture this lever is yellow as I only had a
Sebo X5 on the floor, but the repair is identical). This is what the lever looks like:
Step 2. As you'll see if you look closely, the lever says "closed". Turn the lever towards the front of the vacuum so the lever reads "open".
Step 3. Once the lever is moved to open, lift straight up on the entire handle assembly to remove it from the vacuum cleaner.
Step 4. Once you have the handle assembly out of the vacuum cleaner, turn the handle upside down. You'll be able to see two small metal electrical terminals that connect into the base of the vacuum where the handle meets the vacuum cleaner. Make sure that both terminals are visible. I have seen a few
Sebo's where the handle has come loose, and these terminals no longer make connection to the rest of the vacuum, causing the vacuum not to turn on. You can re-attach the handle into the vacuum cleaner, turn the lever on the side from open back to closed, and test the vacuum to see if it comes on.
Step 5. If the vacuum failed to come on after reinstalling the handle, take the handle back out of the vacuum. Put one of the wires from your electrical tester into each terminal in the bottom of the handle assembly. Make sure that the tester is actually making contact with the metal terminals. It should look like this:
Step 6. With each of the electrical tester wires pushed down into the handle and making sure they are making contact, plug the cord into a standard wall outlet. If current is present, the electrical tester will light up. If not light comes on, try flipping the on/off switch and see if this has an effect on if the tester lights up or not:
As you can see in the picture above, the cord and switch on this vacuum are good. If your tester lights up when you put it into the handle, then this means that your cord and switch are good. This means that either your motor, or PC board have gone bad.
If the tester signals that you don't have any power at the bottom of the handle, then this means that either your switch or your cord is bad.
If you will please let me know the results of the electrical test here on the bottom of the handle, I will then go into the next steps of the repair, and explain how to open up the machine and either replace the cord / switch, or if you did have power here, the
pc board or the motor.
Please just use the clarification request form that you used last time. I hope this was helpful in diagnosing your machine. If this helped you, please be kind and rate the repair as helpful by clicking the thumbs up icons in the top of the repair.
I look forward to helping you fix your
Sebo.
Chris J.
GoVacuum
