To change the ringing on a prostar 816 you first need to be at a display set (doesn't matter what the extension number is).
with the handset down, enter #20 the screen should say MMC DISABLED
enter in 1 2 3 4 1 # (that enables programming)
enter in #62 the screen should say day ring assn
press the line you wish to program
press the buttons for the extensions that you wish to ring (the ones in the right next to the handset)
press # when finished with the line
repeat steps 2 through 5 for the remainder of the lines you wish to change
press # when finished.
Testimonial: "Excellent! This fixed my problem! Thank you so, so much!!!!!"
MERCI BEAUCOUP
fixed it, even downloaded manual. thanks
Hi, same problem. Lines only ring on 1st extension. Tried program #62, but they still don't ring. Exited programming, then went back in, checked #62, and display shows that they are all programmed to ring, but they don't... any suggestions?
what do i do when I cannot make it ring to EVERYWHERE I want it to ring
