Dear,I work for Ingellen Communication Equipment and we are a large fiber optic products manufacturer in Shenzhen. exception with fiber optic transceiver.
Kindly let me know your specific requirements so that i can help
http://www.ingellen.com/fiber-optic-transceiver-c-1.html
The cruise control harness (if equipped)
The forward lamp harness
The SIR system harness
The relay center
Remove the manual transmission shift lever (if equipped).
The Heating, Ventilation and Air Conditioning module (HVACM)
The 22-way engine harness
The stoplamp switch
The vehicle speed sensor (VSS) calibrator module
The clutch or brake release switches
The electronic accelerator (Diesel)
The HVAC control cables (if equipped)
4.2.
Disconnect the cables (if equipped).
Remove the instrument cluster screws and the cluster. Refer to Instrument Cluster Replacement .
Remove the IP storage compartment.
Squeeze the compartment in order to release the compartment.
Remove the IP storage compartment lamp.
Slide the compartment in order to release the compartment.
Remove the low coolant module (Diesel only). Remove the data link connector (DLC).
20.1.
Remove the one screw.
20.2.
Slide the DLC out.
Remove the harness retainer to accessory switches. Remove the fuse panel and the courtesy lamp switch. Remove the ground screw. Remove the harness from the IP. Remove the jumper harness to the remote playback device (if equipped). Remove the courtesy lamp switches. Remove the side window defogger outlets. Remove the park brake cable clips. Remove both of the air outlet deflectors
The assigned IP address and subnet mask displays.
IP address and netmask: 10.1.0.1 255.255.252.0 on VLAN 1,
and address mode: User specified.
Console#
Before you can assign a static IP address to
the switch, you must obtain the following information from your network
administrator:
Console(config)# interface vlan 1
Console(config-if)# ip address 192.168.1.5 255.255.255.0
Console(config)# ip default-gateway 192.168.1.254
Console(config)#
To configure the switch for DHCP or BOOTP:
