Rinnai Toyostove Direct Vent Heater: Toyostove Laser 73 Shipping Logo
Posted on May 09, 2008
Toyostove laser 30
This less than two year old stove cut out one day and signs of soot of the front panel suddenly appeared.. What do you think the problem is?
Anonymous
Level 1:
  • Contributor 57 Answers
  • Posted on Oct 19, 2008
Anonymous
Contributor
Level 1:
Answers
57
Questions
0
Helped
35285
Points
80
Yikes. On the front panel. That can't be good. Have it serviced. ;)
Is it allright to burn part deisel with kerosine in a Toyo laser ignited heating stove?
Only if you want to stink up the house (more than just what the kerosene does) and don't mind dealing with a little soot on the walls and ceiling.
I wouldn't. But the choice is yours to make.
hope this helped you in some way. Please let me know. Thanks.
My Laser 30 keeps getting a ee 12 code ans shuts
Ken,
The screen for the circulating fan has lint on it. Remove it from the back top panel and wipe it off. The lint keeps the air from be able to blow over the stove and it overheats.
Good luck,
Tom
When the model 41 comeson it makes a woolf sound..also the window is sooted up..can you help?
If the burner mat is loose it will make that sound. A loose burner mat will also cause a soot problem. The soot can also be caused by too little air flow thru the burner.
Toyo Stove Laser 30 will not work
The EE-8 indication means there is insufficient air flow to the combustion pot to atomize and ignite the fuel. Check your air switch for a closed condition when the blower is operating.
My laser 30 quit working suddenly last weekend. It has given error EE2, EE6 and EE13. What should I do?
Get it tuned. Sounds like it is plugged up.
If it has been more than 2 years since the last tun-up.
2helpful
Exhuast smell(odor)
J,
If your Laser 56 is giving off fumes it is probably coming from the igniter gasket and the igniter guide gasket. The igniter gasket has broken and needs to be replaced with the new style. The new style cost about $12. The guide gasket is the fiber gasket around the hole the igniter goes in. It has seperated and all you have to do is smash it back together. If you have high temp silicone or furnace cement, you can use either to seal the crack. Any toyotomi dealer can get you the new igniter gasket # 17185580.
Good luck,
Tom Hawkins
[email protected]
1helpful
Need a service manual for laser 30 toyo stove
Remove the flex hose from the back of the stove. If there is a small hole in the back of the stove, stick a pencil in there and spin the motor. Try to start the stove. If the motor won't spin at all or if it spins freely and the stove still shows an EE8 you need a new motor.
You or your local dealer can change the motor in 30 minutes.
Tom Hawkins
Bethel, Alaska
Laser 56 EE6
EE 6 happens for several reasons. Most likely in your case when the stove runs for a while after you turn it back on, the code is due to and over heat. The circulating fan and cover need to be spotless. If they are then the code is due to low fuel, no fuel or dirty filte on tankor stove.
Tom Hawkins
Bethel, Alaska
[email protected]
2answers
Laser 30 model won't heat my 24'x24' Garage?
heating and cooling is rated in btu.or could be watts.for your space to be heated quickly to say 70 deg f. you may need a heater with a rating of 36000 btu.it will heat u up then shut off.if you use a smaller heater it will take longer to heat thus using more energy for the same results.
2helpful
4answers
Toyostove Laser 56 EE 2 error
Tim,
I have been working on Toyo's for 14 years now. During this time I have never seen a flame rod that was bad except ones that people have broken themselves. The rod is just a piece of heavy wire that is insulated against the pot. It is almost impossible to mess it up. Now, that being said, you can have a problem with the flame rod being dirty or sooted. Since your stove is so new I would look at the fuel system. If it is clean I would go after the burner mat. There have been mats lately on new stoves that have caused them to soot up. When this happens the flame rod gets covered with soot and gives the EE2 message. A new stove that has a burner mat problem would be covered by the warranty. Bad fuel that causes a problem will not be covered. The other thing that is not covered is a stove that has had an iced up the exhaust pipe. A good dealer should be able to help you get the stove going and explain the warranty.
Tom Hawkins
[email protected]
Top Rinnai Heating & Cooling Experts
Paul Carew
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
