OKay, I'm a little late on this, sorry. I had to search for the answer myself. I couldn't find it. HOWEVER< after dinking around with it for a few (hours) I found the solution:
1.Turn it on(even if it's dead).
2. Plug it into your computer.
3. wait for the scren with all of the 'zzzz's' shows up, showing that it's connected, but sleeping.
4. hold the PLAY button until you see the screen shut off. Now the screen will turn on, you will see the GPX logo, then the option to 'play'.
5. hit the menu button, and the media player will show up. Once that shows up, you will notice that the battery meter, after a few moments, will start to climb and fall, signifying that it's charging.
I hope that this helps; I can't say that it's the easiest way, but it's the only way that I could find that worked for me. I tried several. I almost returned it because nothing worked and I couldn't find an answer. I hope this helps you, and btw this is my first answer, so sory if I did this wrong!
~ XoToX The Sn4k3 aka Guru Guerin.
It uses a usb cable that comes with the product.
One end to the device and the other to your computers usb port.
it was not helpful what kind of answer is this?!
i am also having the same problem...I know how to connect the player to the computer....set it on there all all and still no charge? Id there a driver or something I need to download???
The device doesn't need a driver to connect to the computer. Do you have the power switch on the player to the on position?
Turn the power switch on the side to on while it is plugged in.
SOURCE: HOW DO I CHARGE MY GPX ML640S MP3 PLAYER
When you connect the MP3 player to your computerwith the supplied USB cable then computer detects the player as an externalstorage device or a Removable disk, you can then view the folder on your MP3player.
This will also charge your MP3 player.
