Question about LG 50PB4D 50 in. Plasma HDTV
I have no sound on two channels only - LG 50PB4D 50 in. Plasma HDTV
    New Friend:
If you are in Australia and have no sound on GEM and 7-Mate, follow the instructions here, to update the TV's (LG 50PB4D-AA) firmware. Once done you will receive sound on these channels.
Posted on Nov 26, 2010
SOURCE:
No sound on some channels (which previously had sound); some channels still have sound
It seems that the "Lang" button on the remote may be pressed by mistake. Try setting the language to English and see if all the channels now broadcast sound.
Mar 10, 2014 | Sharp Televison & Video
No sound on on only one channel
Are you sure this channel broad cast has sound. Please conform with some other TV. If your TV is having sound in all the other channels there is no reason for no sound in one particular channel.
Dec 24, 2013 | Samsung Televison & Video
SOunds shut "off" when changing from HD channel to non-HD channel.
I think you need to look at the sound settings. In particular the type of sound. HD channels often carry AAC sound, suitable for Dolby 5.1 and Standard Channels don't. So the sound system will switch modes when you change channels. However the receiver is not switching back to picking up PCM signals, the type used on SD channels.
Jan 01, 2018 | Harman Kardon AVR 7000
What caused no sound on ABC channels 2 and 21 only?
You would need to ask the broadcaster of the stations that question.
Mar 24, 2017 | Televison & Video
No sound on some channels, some channels have wrong sound for pic
The SAP feature has been turned on. Look for a button that says SAP or go thru the audio menu and turn it off.
Apr 09, 2009 | Televison & Video
With my starview 3 all of sudden my sound is distorted
To get back sound channels ect just select the channel in question press menu,
select installation, select manual scan, click ok on down frequency.
It'll now scan for channels when its finished exit back to normal
tv viewing screen go to the end of your channel listing and the desired channel will be there with sound.
This can be done on any channel with no sound by just selecting that channel following the instructions above.
Hope this helps
Feb 25, 2009 | StarTech.com StarView SV211K 2-port KVM...
Low sound on my Vizio 50" plasma
Most of HD channel broadcast in 5.1 channel sound. Regular channel broadcast in 2.0 channel sound. You TV only have 2 speakers so you will expect the sound will be low compare with the regular channel.
Hope this will help!
Feb 04, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
Center Channel not working on pioneer vsx-d608
Be sure the sound source has a center channel output ie. not a 2 channel source only, try the test tone setup for 5 or 6 channel balance, if no sound from the center channel still then it is looking like maybe the center channel is blown.
Jan 28, 2009 | Pioneer VSX-D608 Receiver
Only left/right have sound during the test
all of the channel are resonding to the test. but you cant notice it bec 5.1 speakers, each channel are designed to respond to a certain frequecies.  the L/R channel your talking about have the mid-range frequecies so it responds clearly compared to other channels...
hope that helps...
Oct 16, 2007 | Logitech Z-5500 Computer Speakers
No sound on my 8year old panasonic tv.
It worked fine yesterday. Sound on all channels. Sometimes the picture goes black on channel 6. We can get it back by going up one channel, then back to 6. it is due to cable signal ie weak. now there is no sound this is due to sound section 1 loose connect in sound section 2 speaker 3 problem in sound section some part must have failed.
Sep 17, 2007 | Panasonic CT-32SX12 32" TV
LG 50PB4D 50 in. Plasma HDTV Logo
402 people viewed this question
Ekse
