Lg tromm dle2512w electric dryer won't go past 6 or go to zero on sensor dry. We can't figure out where the moisture sensor is located. Is it along the inside edge of the outer portion of the lint trap and does it look like 2 parallel chrome bands?
The moisture sensor is located in front grill area inside the dryer. If you look inside the drum where the filter screen mesh is, you will find 2 curved metal bars. Those are your moisture sensors. Hope this helps.
I'd say yes, especially if you replace it yourself to avoid a service call. Top needs to come off (screws at back, then push top back 2 inches and lift off), remove front, remove 4 screws holding front bulk head / front rollers, slip belt off tension pulley, remove drum, reverse to install.
Easy fix. Wipe the capacitance sensing metal stripes located right below the inside of the filter. Make sure the 2 metal stipes are very clean. This measures the capacitance of the clothes and constantly records differences till the clothes are dry.if **** is on these then you would have failure. Porvavor.
