Question about Jet Tech Systems Dishwashers
WATER SRAYER ARM BROKE OFF.HAS A SCREW TO TAKE OFF ARM, ALL I NEED IS ONE ARM TO REPLACE THE SPRAYER ON BOTTOM, DON'T NEED THE WHOLE UNIT..WHERE CAN I PURCHASE ONE?
  • Jet Tech Sys... Master
  • 43,501 Answers
That is not that hard to fix and you can easily buy the parts yourself online...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Posted on Sep 01, 2010
SOURCE:
Top rack not cleaning dishes. model # FDB1050RES2
Hello, check the sprayer arm on the top of the dishwasher inside and to see if it spins. Don't block this spray arm with glasses or dishes that could block the operation of this sprayer cleaning arm.
Now, if it not spinning, check out the fitting arount hing bolt. If this wore out then you will have water pressure lose. Replace if need be. Also, check the feeder water spout that runs the upper spray army, it could be pluged. GB...stewbsion
Aug 31, 2011 | Maytag Dishwasher
Frigidaire Model FDB780RCB0 I am getting water in the machine but it seems the arms are not turning what can I do to get that fixed?
The pump in the dishwasher is supposed to provide enough water pressure to turn the spray arms and make them rotate. The pump is faulty and not giving enough pressure or the arms are stuck.
Try spinning the arms, if they rotate smoothly, you will need to replace the pump.
Aug 03, 2008 | Frigidaire Dishwashers
My Kenmore UltraQuiet 8269644 has been performing poorly. Have cleaned various filters and traps. The spray bars tend to clog with food refuse and now it is leaving a white film on dishes - either...
Your sprayer arms may be clogged.
The upper arm attaches to a tube in the back of the dishwasher. If the support clamps come loose, the upper spray tube will not be flush with the tube and can't carry water to the sprayer arms. Also the sprayer arms can become clogged with paper remnants, bone fragments, or pieces of peeling. You'll need to remove the sprayer arm and flush it at your sink. If there is a jet that is clogged, tweezers will help remove the residue.
Also, dishwasher detergents need HOT water, so be certain the water is at 140 degrees. Make sure your detergent is fresh!
Finally, the bottom of the door INSIDE the washer often get covered with gunk. Be sure and gently wash the bottom of the door INSIDE. You can open the door, spray some window cleaner on the bottom and then gently brush away the 'gunk.' Rinse with hot water from a pitcher or your sink sprayer and this can eliminate some of the residue that is showing on your dishes.
I hope this helps. If it does, please come back to Fixya and rate my answer
Jun 12, 2011 | Dishwashers
I have to initate the spinning of the sprayer arm.
uasally it isnt the spinning of the spary arm that does the fill it is controlled or a timed fill then the motor comes on if there isnt enough water in the unit it will not have enough pressure really need more info though
Jun 02, 2010 | Dishwashers
It is filling and running but the water is not
Could be two different things -- either the pump is not moving water through the sprayer arm, or the sprayer arm isn't free to spin around.
I've fixed one of each in the past year, so either is reasonable.
First, check the easy one -- the sprayer arm.
Open the dishwasher and pull the bottom tray forward so you can reach the sprayer arm.
Reach in and try to spin it around by hand. It should move freely, and if you flick it around, it should spin a full turn around before stopping.
If it's unable to move at all, then look for something stuck like a fork or plastic bag.
If it moves, but very quickly stops spinning, it might be a foreign object or it might need a new sprayer arm assembly. The one I got this year was $38 including shipping.
If the sprayer arm is free and easy to move, then check the water pump:
Start the dishwasher and listen. When it's done filling and sounds like the wash cycle, quickly unlock and open the door.
It shouldn't spray water in your face, but there should be lots of water dripping from the racks and the top (and the dishes, if it's loaded when you do this test!)
If not, then the problem is either a failed main pump or a blocked pump, and the repair will be a bit more money and a lot more time.
If this helps, be sure to click the thumbs-up to tell me so!
Sep 01, 2009 | Maytag Dishwashers
I used regular dish soap in washer and now the sprayer doesn't seem to be working. Is this an easy fix or did I blow it?
Do you mean liquid soap....as this will foam up considerably and cause a mess on your floor...like overflow problems...but even if it was this type of soap it would never inhibit the sprayer arm from working...you can take the sprayer arm off...sometimes a twist nut , sometimes a screw...and clean it as well as inspect it for debris obstructing the holes....other than that the sprayer arm is only there to direct the flow of water..the actual device that forces the water through the sprayer arm is the DW motor...does it run...do you have any water flow...is the DW filling with water...if so... or if not ..check these problems out and if everything checks out it may be a motor issue and a tech will need to be summoned....
I hope this helped to guide you.....thanks and good luck...The Fang
Mar 27, 2009 | Dishwashers
The upper sprayer arm fell off on my Frigidaire FDBB4365FC0.
I just had the same thing happen and fixed it! You might need to remove the upper rack first. In the "Roof" of the dishwasher, you should see what looks like a plastic gear wheel. It will screw off, but you will need to put a little force to get it started. Inside of the gear is a free floating plastic ring with 2 small teeth on one side. Make sure the teeth are facing down through the center hole of the wheel. Hold the ring with one finger, and snap the spray arm back in place. Just screw the assembly back into the washer and all is good... Until it falls out again...
Mar 21, 2009 | Frigidaire PLD4375RFC Dishwasher
Amana ARB8057CSR Bottom Freezer Ice Maker Arm is broken & stuck
If water still continues going to the Ice Maker unplug the pair of wires on the back of the refrigerator that send water up to the ice maker. Now I see I am a little late answering your post, because I just happened to run across it. I was not here when you first posted the problem. Just let me know if you still need help, Thanks Sea Breeze
seabreezehvac@yahoo.com
Dec 18, 2008 | Amana ARB8057CSR Bottom Freezer...
Maytag dishwashwer problem
hi try this In most dishwashers, the water pump is located under the lower sprayer arm. This component pumps the water through the dishwasher. The pump has two impellers, top and bottom. These, as well as other components, can become clogged with food or detergent. Here's how to disassemble the pump:
Step 1: Remove the cap that holds the sprayer arm on.
Step 2: Remove the sprayer arm, the screen, the pump housing, a bolt, the upper impeller, the food disposer blade, a spacer plate, the impeller hood, a flat plate, an O-ring, and the lower impeller. Lay the parts out in order as you disassemble them so that you'll be able to reassemble them properly.
Step 3: Clean the parts thoroughly with a mild detergent solution. If any parts are worn, replace them with new ones made for the dishwasher.
Step 4: Replace any seals, such as the O-ring or other washers, with new ones.
Step 5: Reassemble the pump, keeping the parts in order.
To reach the water pump, remove the sprayer arm and screen and then the pump housing. Remove the bolt, and the pump components can be disassembled.
On some dishwashers, the lower impeller serves as a drain pump. This type of system usually has a reversible motor; machines with nonreversible motors have drain valves, as detailed previously. If your machine possesses this impeller pump system, and the water will not drain from the dishwasher, clean the lower pump impeller. This may solve the problem. Otherwise, call a professional service person.
Sep 12, 2008 | Maytag 24 in. MDB5600A Jetclean II...
Dishwashers Logo
132 people viewed this question
Top Jet Tech Systems Dishwashers Experts
Robert Marsolais
Robert Marsolais
Level 1 Expert
Colin Stickland
Colin Stickland
Are you a Jet Tech Systems Dishwasher Expert? Answer questions, earn points and help others
