HP P2360AA Keyboard/Mouse Logo
Posted on May 09, 2008
Shift key problem
When shift key is pressed along with number key corresponging symbol does not apear on screene
  • 4 more comments
  • Anonymous Aug 22, 2008
    The shift key for getting at, as in wrting email address: my mail " yahoo.com, that is on top of figure 2 does not appear when you press shift key and 2, instead this is what appears """""""""""""""""""""""", please I need solution to this , to send mails I have to go to microsoft words insert symbol and copy, then paste to get email address done.
  • Anonymous Aug 25, 2008
    Shift key will not provide Cap's nor symbols above numbers - HP keyboard.
  • Anonymous Sep 21, 2008
    my shift key won't do caps when i hit it. can't do the email address etc. also a HP computer.
  • hiighline Oct 01, 2008
    when i use the shift key for the @ sign does not work all im getting is ''''''''''''''
  • Lynnsang Oct 23, 2008
    Neither shift key works on laptop. Problem occurs using both built-in and external USB keyboard. Also, some lower case print as caps, erratically. Attempt at single line, file, or shortcut selection by internal touchpad or external mouse causes all available files, shortcuts, or document lines to be selected. Both problems occur in all applications.
  • Pilar Klarmann May 11, 2010
    Does this happen in all programs or some.for example if you open notepad does the same thing happen.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Sep 27, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
1311
Points
That means the symbol assigned for shift-2 is currently assigned to the top left character, likely the " symbol. Press shift-Fn to toggle between symbols until the @ symbol works.
Type the ^ * and other symbols
Your on screen keyboard should have a button labeled ?123, after pressing this to switch to numbers/symbols, press the Shift key to change to additional symbols.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/daniel_e90a831f4dd5fc5d
I dont know how to access all of the symbols that are on a key e.g. one key has a question mark, a slash and two other symbols, one is blue and the other is green
You use teh shift key and the [FN] key to access these extra sets of characters. If it is basically a circle around a symbol then press and Hold the [FN] key while pressing the key you want. If it is the ?,,{,},:," or any of the symbols on the upper part of the number keys at the top of the keyboard just press and hold the shift key while pressing the key.
I need to know how to use the number symbol key on the brothers typewriter em530. It has two symbols above the number 3 key a / and # I want the # sign. When I press the shift and press number 3 it gives...
On brothers there is usually words written above the top row of keys. One of them usually says KBII
Press CODE and that key and you will select the second set of symbols.
DickyO
4helpful
2answers
How do I key an @ symbol? There are multiple symbols on each of the number keys. New to notebook operations
hold shift and press the 2 key on the row above the alphabet keys. the extra symbols are there for if you were to set the computer's OS to a different language keyboard
2answers
How do I choose symbols such as @ from the keys that have several symbols?
Hold down the blue "fn" button when you press the key, it will give you the alternate character.
3helpful
Laptop Keys
This is because it is set to US english keyboard layout rather than UK English layout.
Go to Start -> Control Panel -> Keyboard
and change the language settings
4helpful
How can i make a forward slash on a mexican keyboard. on an american keyboard there is useually one symbol per number on the top keys so you onle have to press shift then the nuber to get the symblol...
On these keyboards, the non colored symbols are typed by holding down the shift key and tapping the symbol. If you want to type the colored key, then you have to hold down the Alt Gr key and tap the colored symbol key.
Some wrong symbls on some keys!?
did u hit teh fn key to change it back
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
