I own a DW716. My blade wobbled. I found that the small bearing on the motor end of the blade spindle had been pressed out a bit. This bearing is right behind (or perhaps attached to) the cap that shows on the motor side of gear assembly housing. I tapped it back in so it was flush to, or even a bit inset of the surface of the gear assembly housing and the wobble disappeared! Yeah! Cheap and Easy.
SOURCE: I HAVE A DW716 MITER SAW AND NEED TO CHANGE THE
Hi there
You do not need to remove the blade gaurd to change the blade. You only need to raise it enough to acces the blade screw. Unplug the saw. Raise the blade arm. Raise the guard to it's upper position. On the left side of the blade, just forward and up slightly from the blade screw is a screw for the guard bracket. Loosen, but do not remove this screw. Once it's loosened the guard can be raised farther exposing the blade screw.
pg 6 of the manual illustrates this process, here's a link so you can see the parts I am discribing,
http://servicenet.dewalt.com/Products/Detail?isId=true&productNumber=DW716&selectedType=12803#
click the pdf icon next to instruction manual, then open the file.
As for the blade wrench, this should have come with the saw, there is a slot in the base for storing the wrench, on the back left side, it slides in and out for safe keeping. If you have misplaced the wrench the DEWALT part number 608563-1
Testimonial: "THANKS FOR THE ADVICE. THE BLADE HAS BEEN REPLACED."
SOURCE: I replaced the blade in
Hello, W/D here.
Remove your new blade. With the hardware, bolt, washer,blade and cups off, try the saw. If it operates correctly, re-examine how the blade is installed One blade cup goes on, followed by the blade, then the other cup, followed by the washer and bolt assembly. If the cups were in the wrong order, the blade can drag against the frame of the saw, pulling too many amps, and tripping the breaker.
Here is a link to DeWalt. Enter your model # for manual download and exploded diagrams.
Best regards, --W/D--
Testimonial: "great advise / troubleshoot"
