SOURCE: connecting powerline ethernet adapters through orange livebox
M. Razaire
SOURCE: I have two Belkin powerline adaptors 200mbps type
Your hard disk is failing and should be replaced. Have you tried to press F1 when you get the message? If this doesn't help try to enter the bios and disable S.M.A.R.T.
Your first goal is to save the data so please do that before it's too late.
SOURCE: belkin powerline adapter doesnt connect to
try resetting the adapter
if not working try updating the firmware
if not working make sure ur adapter is pluged in the same power(electricity) phase of ur house with the router
the house will have different power phase so make sure of it
both the router and the powerline adapter must be in same phase of electricity
SOURCE: I currently am using a Zyxel G 220v 3 wireless
I'm NOT a Windows guru, but I think this is an issue with Windows, not your Zyxel driver.
There is a setting somewhere in the network area of Windows that tells it to automatically connect to a known favorite network if that network appears. I suspect you just have to find that setting, turn it on, and make sure the network you use is in your list of favorites.
SOURCE: I have been using my Belkin powerline adapter
Is the same phase used in your office?(electrical wiring)
