I will assume that you disconnected the switch from the circuit when you did the continuity test -- that is really important.
If so, then i think that the relay inside the top of the unit is stuck on, or the low voltage wires (inside the top) going to the relay are shorted together.
You can easily remove the top after removing 3 (or 4) screws from the upper side of the unit. Be careful to align the vents in the top with the cooling ducts from the motors when replacing the top.
