Gigabyte GAH57MUSB3 Motherboard Logo
Posted on Aug 31, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have gigabyte motherboard H57M-USB3 with Inter core i5-760 processor and kingston k24-7070 1333Mhz memory card which is not working. are they compatible? what can i do to make it work?
Roy
Level 3:
  • Master 2,571 Answers
  • Posted on Aug 31, 2010
Roy
Master
Level 3:
Answers
2571
Questions
0
Helped
494093
Points
7959
It should be, it says this about your memory support.
  • 4 x 1.5V DDR3 DIMM sockets supporting up to 16 GB of system memory
  • DDR3 2200+/1800/1600/1333/1066/800 MHz
  • Here is a list of compatible memory for that motherboard
    http://memoryselector.cnetchannel.com/tigerdirect/results.asp?hvhBlBE0fe0AED
    1helpful
    Keeps trying to reboot when switched-on. Battery checked ok.
    detach all what you can from the motherboard llet only video card , CPU and try to start is so and see the outcome.if is working put bak one at the time and wich is not starting that one is faulty.
    CPU fan & PSU fan working but No display coming to the screen
    There should be some sort of beeps then. No beeps is an indication the CPU or RAM is not seated properly. You need to refer to board manual if there are beeps.
    There is also the matter of... Never mind I just noticed the CPU is an 8 core CPU, but the board supports quad core.
    Board specs
    http://www.gigabyte.com/products/product-page.aspx?pid=3833#sp
    CPU Specs
    http://www.newegg.com/Product/Product.aspx?Item=N82E16819103960
    Double check my findings and go from there. Good Luck
    1helpful
    I have a Acer AX1200-U1510A AM2+ Motherboard and i would like to upgrade the processor, ihave 4 gigs of mem and a 1 gig Gigabyte Gt 610 graphics card. I only have a 240 watt power supply what processo
    Should work with a processor of the same socket type. I'd seriously upgrade the psu myself. Personally I'd upgrade the motherboard and processor to a quad core, and get the fastest ram, look at ebuyer.com, you can buy a bundle upgrade package for less than you may think. :)
    Asus gt 440 computer wont boot up
    Has the card got an additional power socket on the leading edge, make sure you have put the 6 pin PCIX power plug to the card from the PSU.
    1helpful
    Is dual core processor & 256 mb Video RAM supported with Gigabyte 8I915ME motherboard?
    this motherboard can't support any type of dual core or core 2 dou processors.
    but it can support some 256mb AGP video cards( like: 7300gs AGP or 7200gs AGP)
    I want to know that shall i put pentium 4/ 2.4 Ghz/ 533 Fsb/ Processor on this Gigabyte 845GVM-RZ board? will it support ?and i have 1 Gb ddr1 400 mhz ram will this work on this Board?
    Yes for the Intel Pentium 4/2.4GHz/533FSB processor. (Socket 478)
    http://en.wikipedia.org/wiki/List_of_Intel_Pentium_4_microprocessors#Northwood_.28130.C2.A0nm.29
    (Scroll through. What sSpec number is on top of the processor's case? {You are following Anti-Static Precautions, correct? }
    Won't support better than a Prescott Core Pentium 4. (Next chart down)
    The Gigabyte GA-8I ((Supports 400MHz or 533MHz FSB)
    NO to the Ram Memory.
    The Gigabyte GA-8I845GVM-RZ supports DDR Sdram at 333Mhz. (PC2700)
    IMHO it will not support DDR Sdram at 400MHz. (PC3200)
    My reasoning is this;
    Ram Memory typically operates at half of the FSB frequency rate of the Processor.
    Processor FSB > MAXIMUM frequency rate is 533MegaHertz for the GA-8I845GVM-RZ
    Ram memory at 333MHz is doable.
    Not 400MHz.
    No, you won't be able to overclock, and bring the FSB of the Processor high enough for PC3200 Ram Memory.
    (The rest of the motherboard wouldn't work anyway if you did. PCI Express bus, PCI bus, etc., would not match)
    http://www.newegg.com/Product/Product.aspx?Item=N82E16813128238&cm_re=Gigabyte_GA-8I845GVM-RZ-_-13-128-238-_-Product
    Have more questions concerning this, or comments, please post in a Comment.
    Regards,
    joecoolvette
    1helpful
    2answers
    Will my motherboard support a Core 2 Duo processor: GA-8S649MF (Gigabyte Motherboard)
    Every system needs a rock-solid foundation, and that's just what you get with this Gigabyte GA-8S649MF motherboard. It features Socket 775 compatibility and support for Intel Pentium 4 or Pentium Dual-Core processors with 800 MHz front side bus speeds. Two DIMM slots support up to 2 GB of DDR400 system memory.
    Why won't my computer boot?
    phill-29
    To solve this problem at first clear CMOS by removeing CMOS battery then replace ur CPU.
    if it not solve ur problem then check ur bios verson 1002 or not if it 0940 then update ur bios. u can download this update file from this link: http://support.asus.com/download/download.aspx?SLanguage=en-us&model=P5E3
    Top Gigabyte Computers & Internet Experts
    MegaByteMe
    MegaByteMe
    Grand Canyon Tech
    Grand Canyon Tech
    SmartAviator
    SmartAviator
    Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
