Possible fault in the tone ringer IC. This is normally triggered by the incoming signal before the line is switched on. So the IC takes the pulse straight from the incoming voltage , normally from the line in rectifier.
So use a meter to see with a test call for the pulsating voltage on the IC, if present then the IC is faulty. If absent check the inline signal being absent to this section.
SOURCE: Panasonic Kx-T123230 extension to ring
hope this help...
with a handset on hook...press PROGRAM and press 3 (number 3 button) this should give you a choice of which extention you want the phone to ring.. ie 1or 2 or three... Then finally press STORE
SOURCE: panasonic KX - T7436
Someone has to answer the Message Waiting call to cancel...or, try dialing 700 plus your extension to cancel ALL MW lights.
Carl
