Based on your description, it sounds like your Blaupunkt 32-inch flatscreen TV may have a damaged screen. The ink-like appearance and brief flicker followed by a dark screen are indicative of a physical crack or damage to the screen.
It is possible that the TV was able to function normally after the fall, but over time the damage to the screen worsened and is now causing the issues you are experiencing. Unfortunately, this type of damage is typically not repairable and would require a replacement of the entire screen, which can be costly.
If the TV is still under warranty, you may be able to get it repaired or replaced through the manufacturer. Otherwise, you may need to consider purchasing a new TV if the cost of repairing the screen is prohibitive
Yes,if the screen cracked from the inside of the panel and not the outside,you are entitled to either a replacement or warrantied repair. That was caused by heat and we have serviced heat related manufacturer design flaws. Unfortunatly,it is out of warranty,but if it was caused through normal use and not user error,a technician will have to confirm it was internal cracks. MAKE SURE you call philips for an authorized servicer and have the reference number on hand,model number,and serial number.
damaged lcd screen are not repaireable but are replacable. mostly expensive depending on its size. handling, shipping or transporting units with lcd such as plasma tvs should be given extra care.
My mothers 42' flat screen TV got knocked over. Now there is a large crack on the inside corner. What would it cost to get it fixed. Please contact me at [email protected].
