Generally, when you have a ghosting problem, the issue is with the fusing unit. If you have a new fusing unit (or if you can get one) install the new unit and the problem should go away.
If you don't have access to a new fuser, you can try replacing the drum/imaging unit. Sometimes a ghosting problem can be caused by a bad cleaning unit (inside the imaging unit), but usually it's the fuser causing the problem.
