Bose Acoustimass 10 III System Logo
Posted on Aug 31, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hello, I'm relocating to Germany and I'm wondering whether there is a simple possibility to run the Acoustimass 10 III with 220V. In the old times, I remember, there was always one and the same transformer in those units and you could change one connection to have the two primary coils in parallel or in series. There was no other difference between the Europen and North Amarican version.
Manuel Ribeiro
Level 1:
Habit-Forming:
New Friend:
  • Contributor 24 Answers
  • Posted on Feb 20, 2016
Manuel Ribeiro
Contributor
Level 1:
Habit-Forming:
New Friend:
Answers
24
Questions
0
Helped
11750
Points
64
I'm running a 110v accoustimass on 220v. Just buy a stepdown transformer and you're in the clear. Please dimention the transformer with slack. For instance my accoustimass has a 250 watt consumption, so a 400 or 500w is recommended.
Anonymous
Level 2:
New Friend:
  • Expert 52 Answers
  • Posted on Sep 01, 2010
Anonymous
Expert
Level 2:
New Friend:
Answers
52
Questions
0
Helped
10615
Points
101
It will work on 220/240V 50/60 Hz You just need the AC adaptor
How find schematic diagram acoustimass 10 III
No kidding but "good luck". Bose doesn't like telling anyone anything about the workungs or specs of their products. You'll only hear them tell you "it's the end all, be all product". And you're blindly supposed to accept that.
I have a Bose Acoustimass 6 Series III the receiver is Yamaha 3066, this system is a 5.1 surround sound. Then I bought a pair of Bose 901 Series VI Direct/Reflective speaker system with active equaliz
The setup is possible, but with several compromises. First off, to use the active equalizer, you'll need to insert this into one of the 2 channel AV channels limiting your listening with the equalizer to stereo only. The acoustimass subwoofer acts a driver/power regulator for the little cube speakers. It probably will not be able to drive the 901s at the correct level when attached to the Acoustimass unit as front left/right speakers. You could try running a dedicated set of speaker leads to the 901s which may work and still allow surround sound, but you'll lose the equalization capability on the 901s.
Where can i find a bose 15 pin input cable for the acoustimass model?
Try eBay. Lots of Bose cables. Search engines provide faster answers than tossing something like this out to us for a possible answer.
14helpful
Need new system input cable for acoustimass 10
I've made a diagram of my serial cable. You can easily make one with some speaker wire and a 15-pin d-type female serial connector. Solder the wires as shown in the diagram.
19helpful
2answers
Bose audio input receiver cable 15 pin
You can buy it on ebay but it's cheaper just to make one. If you can solder, all you need is a female 15-pin d-type connector and a bunch of speaker wire. Here is a diagram of the connections.
My sound in cable was missplase and can i make it my self and pls any body can send me the cable structre. pls...........
Here's a diagram of the 15-pin serial input cable that came with my Acoustimass 10 IV system. You just need a 15-pin female d-type connector, one RCA connector and a lot of speaker wire. Here's my diagram:
6helpful
Bose Acoustimass 8 pin Cable
Bose Lifestyle 3 or 5 not sure which. DIN 8 pin to 2 RCA's
Top Bose Audio Players & Recorders Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
ZJ Limited
ZJ Limited
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
