Spilt juice on my laptop now the screen wont work at all.all the power lights come on no problem,what can it be?
Wow, bad luck day. immediately flip the laptop upside down in an open position so the keyboard is flat on the table use some paper towel under the keyboard... more comments. to follow... do this immediately
I guess i assume this just happened, how long ago did this take place?
You dont want juice getting any further down into the laptop than the keyboard, as juice will cause circuitry failure.(leave itupside down on the towel if it just happened) . Fortunately laptop manufacturers sometimes account for this and put rubber guards under the keypads. I will go find you a pic of how to get the keyboard out so you can clean it on your model, watch for the comment.
STEP 1
First of all, turn off the laptop and remove the battery.
I'll start disassembly with removing the keyboard (Steps 1-6).
Using a sharp object carefully lift up the plastic bezel above the keyboard.
STEP 2
Remove the keyboard bezel.
STEP 3
Remove four screws securing the keyboard to the laptop
STEP 4
Carefully lift up the keyboard from the laptop.
STEP 5
Access the keyboard cable connector located under the keyboard.
You have to unlock the connector and release the cable before removing the keyboard.
STEP 6
In order to unlock the keyboard cable connector move the locking clip towards the LCD screen.Its Grey in the picture below.
Move it only about 2 millimeters. The locking clip must stay attached to the connector base.
BE VERY CAREFUL THE GREY CLIP ONLY MOVES 2mm
if you break it you will need to replace the Mainboard
now that you have your keyboard out you can try to finish cleaning the keyboard, with some windex and paper towel, without risking getting any more juice or what not inside the computer.
lastly, if this happed a few days ago. you will need to order another keypad for your unit, sometimes these can be found on ebay for less. Until you get a replacement use a usb keypad and mouse.
If this happened a few minutes ago. Clean it as best you can with paper towel , windex or glass cleaner. and use a can or two of compressed air to blow out between the keys really well. Then leave it disconnected for a few days while it dries. The longer you wait the better you chances it will work again. you can use the USB keyboard and mouse while it dries granted you dont touch ANY of the other electronics while you are using your laptop in that open fashion.
Hope that helps you. Best of luck
Gurvy!
did this help?
Thanks for the help.
