"I know I'm a biot late to the party here but I just worked on an M3027 with that same error. It turned out to be the scanner head lock was in the locked state. Tried unlocking with the machine still on which didn't clear the error but after a power-cycle with the head unlocked the error was cleared. Nice simple and free solution!" Read more here: error 30 01 34 scanner failure
Disconnect the battery for a few minutes then re-attach. Or, call a local auto parts store and they most likely will read the code and clear it for you. also you can buy one obd2 scanner read and clear the fault coder by yourself if u mean the loud noisy horn alarm DIY car obd2 code scanner online shopping
you can clear the codes with related code scnner, such us the Super Scanner ET801 BMW Code Scanner, it can read and erase trouble codes for all bmw series between 1997 to 2008 year.
You can change the scanner setting and increase image resolution before scanning,after that your image will get clear. Download the mention below manual & read the software section para.
First you must purchase a scanner with OBDII capabilities that can read and clear codes. Then you connect the scanner to the OBD diagnostic connector under the dash and perform the code clearing per the instructions with the scanner. A generic OBD scanner with these capabilities can be purchased at the local parts stores for around $70.
1) Clear key ON - Exposure mode select key ON - Clear key ON - Exposure mode select key ON (The machine is ready for entry of the main code of simulation.) 2) Main code input by 10-key ? Start key ON 3) Sub code input by 10-key ? Start key ON The machine enters the selected simulation mode. Press the start key to start the operation of the selected simulation. Main Code =(14 Used to cancel the self diag other than U2 trouble.) Sub code = 0
* Canceling the simulation and returning to the normal mode 1) Press the clear key. Copy SIM 14
Did you have the code cleared after you installed the new part because the ECM cannot clear itself, even though you installed a new part and the code is still in the system? You need to have the code erased with a OBD II scanner.
you need a scanner obd 1 you could undo the battery or pull a fuse but obd2 needs a scanner too clear the codes you could go too autozone they will read the codes for you and clear them and try too sell you a part that probly wont fix it but if you clear it and its not fixed it will come back
You'll need to have a code reader or scanner with reset ability. Some auto parts stores, Auto Zone and ORieleys come to mind, will rent you a scanner or Loan you a scanner and at times will actually connect the scanner and clear it for you or at least tell you what the light is activated for for free. You could try looking it up in a Haynes repair Manual for your vehicle. On some models there are methods for reading and clearing the codes with out a Scanner tool but they are usually vehicle make and model specific.
Hello there: once the vehical is repaired simply take the vehical to your local autozone or kragen store and have them hook up the free handheld diagnostic machine and have them clear the code i do this quite often best regards michael
