? 1:52
https://www.youtube.com/watch?v=wsqbE_ztTYw
May 12, 2009 - Uploaded by ehowauto
Hi i have a locked driver side door that will not open.when i lift the locking ... I press the power lock, and hear a sound but all four doors remain locked or unlocked ... Hey sorry for the botherbut I need help.my key button don't unlock or lock.the button inside the car doesn't work either to unlock or lock.so I'm ...
? 3:37
https://www.youtube.com/watch?v=TSE0fOrujW0
Aug 16, 2012 - Uploaded by Scotty Kilmer
2005 Mustang wont start or crank from the key.. wont say nothing good battery ..... all I hear is clicking noise my radio and lights and everything comes on but it will not do nothing what couldthis be have I blown something?
That lock icon indicates a locked door, and if you can open your door with it locked, your door lock will need to be reset. Your instruction manual should have your reset procedure listed in back. But if your door IS locked, you will need to manually drain out the water before it will open.
Go back through the process that you performed. You may have miss a step of not connected somthing. Also you may want to make sue there is nothing in the pump. If a pingpong ball was in ther ther also may be some coins.
As for the user whose machine will not drain and sounds as though a chain is clanking, the solution is probably a coin caught in the drain pump. I just had the same problem. Access the pump from the bottom of the machine. 4 screws hold the mounting bracket on undo those, the electrical connection and two hose to the pump. Undo three screws holding impeller to motor and coin can fall out. Examine for damage if it is not too tore up, put back together. Keep in mind that when you unclamp the hoses that water will come out.
