Question about Samsung RS2534 Side by Side Refrigerator
SAMSUNG RS253BAWW NOT WORKING
I have the above model. About a month ago I noticed that my fridge was making noise. I removed that back pannel and noticed that there was an excesive amount of ice build up around the fan so I unpluged that whole unit, removed the back pannel and defrosted the ice build up. I noticed a couple of days later that the ice maker was no longer making ice automaticly. I can ust the test button and make ice manually. The water flows fine to the tray and it freezes fine but it will not dump and refill on its own. I was trying to fix this so I installed a new water filter and reset the filter life with no luck. Then i thought that I could unplug the fridge to "reset it". Now the temp controlls for the whole unit seem to be working improperly. I have to use the power cool setting to get the fridge and the freezer temperatures down to where they should be at. Then the fridge and freezer begin to warm back up. using the power cool function I can get the temps to -6 freez, and 34 fridge. then they rise to 35 freez, 51 fridge. Please Help!!!!
  • cwarren88 May 08, 2008
    I understand that the ice maker will not cycle untill the temp gets to a lower temp. There are two main problems First and mot important is the fact that the unit is not self regulating its temp properly, Secondary is the ice maker issue. Is there a way that i can test certain things to ensure that they are properly functioning once I remove the back pannel?
    Scholar:
  • 150 Answers
The ice maker wont cycle untill the temp of the ice is around 10 degrees so if the freezer is at 15 or 20 due to some other malfunction then you will see the maker full of ice but it wont harvest and make another batch. so you could have a sensor bad, control malfunction, refrigeration issue, compressor, defrost system malfunction(you mentioned ice build up)
Posted on May 08, 2008
  • andrew kinslow May 08, 2008
    yes like I said you have a problem with one of the components listed in my last solution all of them can cause the symptoms you described. with the limited info available on your message I can't narrow it down any further. you can check them all with a multimeter. getting the values for the thermistors might be a trick but you can check if the are open or shorted
SOURCE:
Kitchenaid superba making noise
Check the fan on the back and blow air through it to clear any dust accumulation.
May 04, 2017 | KitchenAid Superba KSRG25FK Side by Side...
Samsung RF266AEPN BUZZING NOISE and back Panel Iced
Sometimes they ice up because the defrost cycle does not work, check for a faulty fuse, in the circuit board.
Jun 04, 2017 | Samsung RF266AEPN
Fridge freezer probs
From the sound of it I would looking at the evaporator fan in the freezer. This is what circulates air and actually cools the refrigerator as well as the freezer
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
May 21, 2012 | Maytag Refrigerators
My fridge - model RS583HDP started making a noise in the fridge section a few days ago, like the fan was working quite loudly and every time you openned the fridge section, the fan slowed right down and...
try to lubricate or replace bushing of your evaporator fan maybe it has awear in tear that fan hard to rotate this can cause a noise and poor circulation of air cause of temp. rise
Feb 13, 2011 | Samsung Refrigerators
I've had my samsung bottom freezer counter depth fridge for just over a year and in the last 5 to 6 months it's started to periodically make a very loud humming noise. Should I be concerned that there is...
The freezer compartment fan may have Icing or the motor is going.....Remove the trays and remove the rear cover. The fan and Freezer evaporator are behind that cover.
The fan doesn't run all the time.
If you have an ice maker it too can make buzzing sounds. Just turn off the Ice maker to eliminate it as a source.
Here's a link to the service manual for the 215
http://www.ajmadison.com/ajmadison/itemdocs/DA68-01778A-EN.pdf
Mar 08, 2010 | Samsung RB215LASH
MY SAMSUNG FRIDGE/FREEZER HAS A PROBLEM MY TEMPERATURE ON THE FRIDGE IS FLASHING. THE MODEL NO. RS21DCNS THE FRIDGE IS NOT COLD ENONUGH AND I PUT THE TEMPRATURE ON HIGH AND IMMEDIANTLY IT WENT BACK DOWN....
This is caused by the ice building up in at the back - the fan catches the ice and eventually will stop. With the fan malfunctioning the temperature will rise and the light then flashes. Keep searching the web, and you will find instructions how to remove the back and de-ice it. I had exactly the same problem 2 months ago. Make sure that it is fully de-iced, including the tray at the bottom. Ours has worked OK since!
Jul 07, 2009 | Samsung Refrigerators
Samsung RS2630SH Refrigerator
You have the fan problem. Full the refrigerator out and open the lower back cover you will see you fan is almost become bad. If you apply WD1040 oil you can use it about 3 more months. Then It will die out. I think you better change it now or later on you refrigerator become hot and hotter. If you are careless, you can get burn you skin. I had this problem. Frist, the fan made noise on and off. I applied oil into the motor. It was working about 3 months then I died out. The front end of refrigerator become a heater.
Go to online partstore.com and buy a fan with your fan model.
Dec 01, 2008 | Samsung RS2630SH Side by Side Refrigerator
Loud noise from the freezer side
The problem is a buildup of ice on the plastic housing (the curved plastic bit) in the back of the freezer under the fixed shelf where the icetub goes. The fan behind this plastic housing is hitting the ice when the defrost comes on.
Unplug the fridge, unpack the freezer, remove the four screws in the back, take off the sheetmetal backing and let the fridge thaw. You can remove the plastic piece after a while and get the ice off (be careful not to remove the styrofoam insulation by going too quickly).
Reassemble and you're back in business, for a few months. I'm never buying Samsung again myself.
Sep 20, 2008 | Samsung RS2630SH Side by Side Refrigerator
Electrical noise
If the noise from the compressor sounds like a humming followed by a click, the compressor is "short cycling". Could be either the compressor relay or the compressor itself is bad. Not sure on the hissing noise. Could be just a loose panel that needs to be tightened or adjusted.
Apr 07, 2008 | Samsung RB1955 Bottom Freezer Refrigerator
Samsung RS2534 Side by Side Refrigerator Logo
1,446 people viewed this question
Top Samsung Refrigerators Experts
Paul
Gerry Harvey
Gerry Harvey
jasbo
jasbo
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
