The door won't open at the end of the cycle. Any cycle. Any of the wash cycles, plus the drain or spin cycle. I've tried them all. I can't get the door open. Thanks for your help, Michele
I have the same issue. Runs fine. All cycles. Drains. Door will not open. Tried to reset the machine and it didn't work. Display is fine. Child lock is off. I am at a loss...I have the same issue. Runs fine. All cycles. Drains. Door will not open. Tried to reset the machine and it didn't work. Display is fine. Child lock is off. I am at a loss...
You can't post conmments that contain an email address.
Michele99, So when you put it on drain, do you here the machine trying to drain the water? After it finishes draining, (you have to wait a few minutes, it should then have a blinking light
on the Finished/Door locked light.
Are you waiting for it to finish?
My Bosch washer turns "on" and water runs but it does not spin or complete wash. I hear the machine "clicking" as if it is attempting to to function but no spin or full wash cycle.
check the drain pump and make sure it is not plugged if there is anything stopping the pump the washer will not function.
you may also need to check the door lock
Are you sure that your washer spins? that your pump drains? You should not have this problem. Do you load your laundry properly (too much laundry- should not be more than 3/4 of the diameter of the drum)?
The door is probably locked, because the water is still draining. If this is not the answer, the the suction between the dor and the opening is too strong and you must get it weakened by a professional. There is one more solution, and that is to unplug the machine, reset it, and then try opening the door.
suspect you have filter blocked or a foreign object in pump.
put drain hose as low as possible in a bowl and drain as much water as you can
undo filter but be carefull, water will come out in considerable quantities.
clean filter
check nothing stuck in pump impellor
