After installed it, i just reboot my iphone and it wont start.. just appear apple..
anyone have any idea?
thanks
Try turning on voice over and rapidly push the on and off button till the apple sports with a loading ring on it after that it should be find if not try YouTube for help if still nothing contact apple and make an appoint
Find your solution from the list,
Apple Iphone Smartphone
Codes:
Software & Hardware Problems
Find Your Solutions for Apple Products:
Apple Iphone 3G
Apple iPod Touch Digital Media Player
Quit all itune programs running hold home button and power button till screen goes blank then take out cable or dock then hold home button and while holding reconnect cable and DONT LET HOME BUTTON GO and wait till itune pic show and then let home button go and go to itunes and it well tell u its in recovery mode then let it download the update and start over after downloade is done
MoTion93
Hi. I had the same problem with biteSMS v1.1.5.
It took me some time to figure out that the DYLD_INSERT_LIBRARY entry in:
/System/Library/LaunchDaemons/com.apple.SpringBoard.plist for biteSMS
made my SpringBoard crash all the time... (Rebooting with Apple-Logo)
After i edited the file with plutil, and removing the entry, all was ok again :-))
(You do not even have to reconvert it back to Binary form..)
ralfko
Guys USE IBricker 0.93 to boot your phones from restack stuck mode.
The support team at biteSMS would like to work through the problem with you (to see if it's related to the app), can you please email us at [email protected].
Also email what iPhone version are you running?
Have you also tried a cold-reset, hold down power and home button for 10-secs together?
What version is it 1.9 or the new 1.10?
after install BIteSMS and raging thunder....
Just happened to me. Iphone on 1.1.4. BiteSMS was working well on 1.09 I upgraded it to 1.1 restarted the iphone as requested now it won't successfully restart. Looks like it has restarted but no response from the screen and every couple of minutes the screen resets.
No response from the phone when I call it.
Phone will sync in itunes.
i have got the solution 2days ago...
i just restore it... and jailbreak, unlock, do everything using ziphone.
so its like new..
i should start from the first again.
I installed "Mobile Enhancer" from installer and it told me to restart iphone to take effect. I turned it off and when I turned it back on it displayed the apple and then this:
AppleMRVL868x: Ethernet address 00:1c:b3
:46:65:5b
AppleMRVL868x: Command line options and
current values used by driver
AppleMRVL868x: marvel-debug=0xc8
AppleMRVL868x: marvell-feature-flags
=0x7
AppleMRVL868x: marvell-inactivity-ti
meout=0
AppleMRVL868x: marvell-powersave-tim
eout=0
AppleMRVL868x: marvell-powersave-lis
tenint=1
AppleMRVL868x: marvell-ps-confirm-de
lay=15
AppleMRVL868x: marvell-retry-limit=1
5
AppleMRVL868x: marvell-sdio-pulldown
s=0
AppleMRVL868x: WTE=0x0
AppleMRVL868x: Loading Main Program
AppleMRVL868x: Firmware Loaded.
AppleMRVL868x Hardware Details:
Firmware Version: 8.108.3.p65 (0x41086
c03)
I/O Version: 0x0002
Hardware Version: 0x0011
Mac Address: 00:1c:b3:46:65:5b
:/ root#
I can't sync it with iTunes. I restarted it again by pressing both buttons and same thing happens. Any help please?
My iphone seems to be ruined from the same thing!!
It wont be detected by anything,
it has the same error msgs and when you plug it in it says Ipod stack cant start - need configuration!!!
help please
befor i install thems I turned it off and when I turned it back on it displayed the apple
Please help me! I installed a lot of games to my iphone from my iphone it self, those different contributors...Now, i restarted it couple of times to be configured or added it successfully and it works...then, after i stopped downloading, i restarted it one more time, then it wont open the main screen anymore. The apple logo appear but til there...my iphone getting hot for long to start...pls do help me, thank you and im looking forward.
Halo, I have the same problem with biteSMS. After I restart my phone, the screen is stuck at the apple logo. I already deleted all the biteSMS application files from the iphone using iphone browser. I saw the solution about editing the entry in com.apple.springboard.plist, but I am not sure, because when I open it using the notepad, it looks like this:
bplist00ö
ULabel\MachServices_EnvironmentVariablesXOnDemandZServiceIPC_ProgramArguments_com.apple.SpringBoardñ
_com.apple.springboard.migserver ñ
_DYLD_INSERT_LIBRARIES_e/Library/Frameworks/SummerBoard.framework/SummerBoard.dylib:/var/root/Library/biteSMS/biteSMSsb.dylib¡_8/System/Library/CoreServices/SpringBoard.app/SpringBoard
could someone please let me know which one I should remove from the above command?
thanks very much
