First make sure you have the correct USB drivers for your phone installed on your pc. Go to device manager and see if your phone or mass storage device is listed. If not, download the drivers here, http://www.samsung.com/us/support/downloads. Make sure debugging on your phone is enabled. Please refer to the following:
To set the Samsung Galaxy S2 to USB Mass Storage (MSC) mode, go into "Settings > Applications > Development" and enable "USB debugging".
Then drag the status bar down and tap on "USB connected".
The "USB connected" screen with the large green Android icon will appear. Tap on "Connect USB storage".
A confirmation dialog box will appear. Tap "OK". The green Android icon will turn orange, indicating that the phone is now in USB Mass Storage mode and should now appear as USB disk drives in "Devices with Removable Storage" and be assigned drive letters.
Samsung Galaxy S2 (Android 4.0)
To set the Samsung Galaxy S2 to USB Mass Storage (MSC) mode, go into "Settings > More... > USB utilities" and tap on "Connect Storage to PC".
Then plug the USB cable into the device and connect to your computer.
Samsung Galaxy S2 (Android 2.3)
plug USB cables into phone & PC, open the phone and see "USB config" 'Mass Storage' or 'Com port'. highlight 'Mass Storage' and 'OK', PC will recognize the phone as removeable drive 'x' usually 'e'. there will be different folders for music, photos, etc, use the removeable drive like any other drive to xfer files between the phone and the PC.......
If Camera (sony Cyber shot) is displaying " USB mass storage Memory Stick" every time i plug in the USB, click on My Computer > Mass Storage icon > open folder and copy files/ pictures and paste them some where in your computer like My Pictures of My Documents etc. Thanks.
Your PC is seeing your camera memory as USB mass storage and this is OK. Nothing is wrong with this. Follow the screens and you will see that the computer will see your camera as USB mass storage, and when you open the folder on your computer the camera pictures will be there.
Windows is set up to see cameras as USB mass storage devices for simplicity, so your computer can accept pictures from any camera that connects by USB without needing special software.
If this bothers you, most cameras are sold with their own special software that starts when the camera is connected. Check your users manual and follow the instructions for installing or downloading the software.
The quickest way to do this is to put your phone into Mass Storage Mode then connect it via the USB cable to your computer. Your phone shows up as a USB Mass Storage Device and you can select the folders you want to download your pictures from.
To set your phone to Mass Storage Mode, do the following:
- Go to the main menu - Select Settings - Then Select Phone Settings - Choose PC Connections from the menu - And then click on Mass Storage.
When you connect the USB cable to your computer, your phone will show up as a USB Storage device and you can just copy and past files to it like you would a USB Thumb drive. If you select the Samsung PC Studio option...your file transfers will take ALL DAY. Just use Mass Storage mode. Good luck.
A USB mass storage means a storage module or storage unit for data such as pictures, music, etc. that you can plug into the USB on a computer. A cellphone becomes a USB mass storage when plugged in a computer because inside a computer is a place to store such data. If you have further questions do reply back.
