Maybe, but other failures may occur soon. This usually is a "waste ink absorber is full" message. If you disassemble the printer, you will find absorbant pads at the sides (one is right under where the ink cartridge rests when not in use). If you remove the pads, blot off the excess ink and then rinse them until the water runs clean. Then let the pads dry (you can use a blow dryer to speed up the final drying step). Then reassemble the printer.
Next you need to reset the counter for the waste ink. Epson provides a utility to do this for some models: http://www.epson.com/cgi-bin/Store/support/InkPadsForm.jsp?cookies=no&com.broadvision.session.new=Yes . You need to enter your printer serial number to get the link.
I hope this helps.
Sure that will help!
SOURCE: EPSON PRINTER R22O
display This massages Parts inside your printer are near the end of their service life.
See your printer documentation.
SOURCE: Epson Sylus Photo RX600
press the on, stop, color & b&w buttons at same time and hold them down for awhile......seams to reset everything....good luck
