Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
SOURCE: Roper washer leaves clothes wet after spin cycle.
Thanks, Master Tech; I was having the same problem as Jason. When I put the pen in place, I realized that the motor was running, but the tub wasn't spinning (which I thought it was because of the sound of the motor). So, I put my hand in and gave it a push/spin and it started turning on its own after I did that.. So, I'm going to let it run and see what happens when the cycle is done. At least its a start in the right direction!
SOURCE: Spin cycle doesn't spin clothes well
pump stuck with the lint just tille the washer open 5 or 6 screws on the pump clean the lint wrap around the wheel pump it will fix the problem good luck.this machine is a lemon get sue by some other state the company make it already lost the case why they still sell in cali
SOURCE: washer washes clothes.spins but when removing
Check the belt. If you have an oil leak also it is time for a techo to do a service on the machine.
SOURCE: clothes are still wet after high spin
I always ask for clarification 2Pleach if I can’t decode from the trouble description if the machine type is a FAV6800A/FAV9800A. I know what forum I’m in….. Why shoot from the hip…..Sometimes I can and will offer a solution without asking for the Mdl# - s/n if I see enough key words in the trouble description.
This Best Services board doesn't ask the forum member for Model# or S/N as a normal DIY board should.
lorraine97ca See this Clutch repair post for the fix action if you have those machine types and want to DIY. 2Pleach please see my profile under dh1200s and FAV6800AWDIY along with my ratings for my many hundreds of post at no $ gain to me. I have spent many hundreds of personnel time to support others. But I do enjoy the challenge that’s the only reason I bother.
Just a fellow owner trying to help other owners save a $1K machine from bulk trash pick up. **** --- Rich
