Maytag PAV2300 Top Load Washer Logo
Anonymous Posted on Aug 29, 2010
Maytag performa PAV2300AWW does not spin (wash cycle works fine). During the spin cycle the tub does not rotate...but i can hear the motor running...water drains...Pls help
Anonymous
Level 3:
  • Maytag Master 43,501 Answers
  • Posted on Aug 29, 2010
Anonymous
Maytag Master
Level 3:
Answers
43501
Questions
0
Helped
10844298
Points
101584
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
  • 1 more comment
  • Anonymous Aug 29, 2010
    Thanks Heatman for the information...
    One question -- During the wash cycle I see that the agitator is rotating in both directions, but the wash tub doesnt rotate at all...is that how it is supposed to be...?
    Yes, that is normal operation...
  • Anonymous Aug 30, 2010
    Thanks again....Any idea if "Maytag performa PAV2300AWW" is a drive type or belt type or clutch type or coupler type...?
Maytag Performa pav2300aww stops and starts
If it's stopping during a wash cycle, suspect the heater elemant not heating up and moving the controller on. See if it runs fine during a spin/drain cycle. If it is very slow on all programs, try the noise filter capacitor before condemning the controller.
3helpful
MAYTAG PERFORMA MODEL# PAV2300AWW, REVISION#12, SERIAL#12296390ZM Washer filled but made loud grinding sound while agitating. I couldn't drain water on spin cycle. Now it has stopped working, I smelled...
hello you need to change drum rollers but if u remarked water dawn the washer and burn smell it could be the motor OR THE BELT because when the drum stop turning or turn slowly the motor turn fast on the belt when spin time it make this smell .
1helpful
Maytag Performa, Noisey spin cycle, now does not work
the belt may be old and stretched/slipping...if it is stretched and slipping it will cause the squealing .............otherwise, check the pulley for the belt/motor to see if it is okay and the motor itself copuld be worn out if the belt looks ok............be careful, you can get zapped if you touch a wire and also if the motor is burned up it can cause a fire so watch carefully and you should be able to see which of these possibilities are the problem..............
4helpful
Grinding sound during agitation cycle on my Maytag Performa
Its probably you stator plate and rotor. But you need special tools for this repair. There a spring that is under 200 pounds of pressure and if you take the screws off that hold the plate its going to fly into you face if your dont use the special tools to depress the spring. Is it more of a clanking kinda of noise? DOes it olnly happen with heavy loads? Try this out. Fill the washer with water only. and get it into a wash cycle with water only. If there is no noise then put in like a load of towels. A heavy load. Now if you hear the noise now then its for sure you stator plate and rotor..hope this helps, but like i said you need those special tools to do this repair or injury can result from the spring part.
Maytag performa PAV2300AWW will not spin but sounds like it is.
I think you have guessed it right. There is probably something stuck between the tubs. I have seen this caused by a lot of things. You should look for things as small as coins, shirt buttons, cufflinks etc., Also I advice you not to turn on the machine until the blockage is removed.
Good Luck,
Sai.
Maytag Performa PAV2300AWW Wahing Machine
Banging side to side during spin cycle.
Top Maytag Washing Machines Experts
ZJ Limited
ZJ Limited
john h
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
