Tomtom GO 910 GPS Receiver Logo
Posted on May 07, 2008
Wrong country! Hope you can help. Was driving into central London one day when my TomTom just switched itself off! I kept trying to plug in the destination postcode but it would not recognise it. Now when I try my Surrey GU postcodes it directs me to Guam in SE Asia!! I can't get it back to recognising a UK postcode!! What do I do!! Help!!
A
Anonymous
Choose again your right map and than start a navigation by use adress / street and number, than it works fine again :)
7helpful
2answers
My tomtom gets stuck on a destination and I cannot plan another route. Have tried turning tomtom off and on again to no effect. Problem clears itself after several days.....
It may help to do an update on your item to fix any problems.
You'll need to download the tomtom home software, which should guide you through the process.
You can download the software from Tomtom.com at the following address:
http://www.tomtom.com/services/service.php?id=16
Hope this helps.
3helpful
My device starts up makes me select country, time and then freezes and shuts down at select a voice
Connect it to the dock and your PC usb. Go to my computer and copy all of the files in the removable disk that appears when you plug it in. Save them to a safe place on your computer.
Go to http://www.tomtom.com/ click 'Support' where you will find repair tools and guides. If anything goes wrong then copy and paste your backed up files back into the removable drive and overwrite.
Please rate if this helped you.
Regards
Phill
2helpful
After attempting to update my tomtom910 I have not been able to get beyond starting up and it switching itself off after a couple of mins when fully charged
If you updated the operating system, and you are having this problem then something went wrong with the update. Hope you made a backup before you updated. If you did not, connect your 910 to the pc and then go to "My Computer" and open the drive for your 910. Delete "ttsystem". Now open TomTom Home and let TomTom Home install the operating system for your 910.
Driving back from Dorset to London today the screen froze around 90 miles from London. it's displaying waiting for valid GPS signal. Any ideas on a solution.
yep, possibly slipped a cog ( metaphorically)
try resetting the BAUD rate and the PORT in settings. can happen if some electrical interference was experienced ( UFO?)
1helpful
Tom tom 125 will not turn on when green light is on.... we did get it to come on once... when it was plugged into charger but then it kept going off and on like maybe there was something wrong with the...
Connect it to your computer (green light should be on) and hold down the power button for at least 15 seconds to reset it. Let go of the power button once the device reboots. Run HOME (www.tomtom.com/home) and download/install any updates that it finds.
Trying to load the home, it says to just plug into the tomtom,
Be sure that you have the Tom Tom turned on. Also, if you have it plugged into a front USB port on your computer, try connecting it to one on the back. I hope this helps.
WD Notebook Hard disk power problem
The power cord connects to a little circuit board inside the case, and the hard drive itself connects to the board. I would think that if you damaged anything it would be the board but not the drive. You could try taking the drive out of the case and connecting it directly to your computer (or you could get a computer shop or computer geek friend to do it if you don't feel up to it). If the drive itself isn't damaged you will be able to read your data.
My tomtome one
I have a Tomtom One but can get no where on it as I put in the wrong country. I need a way to chanbe the country to USA please.
1helpful
10answers
TomTom 520 won't start
Hi all,
I got the following response to this little problem. Will try it out and hopefully my 520 will work again soon.
To ensure that your device is correctly connected to your PC, please do the following:-
STEP 1 Run the Registry Cleaner Tool
• Disconnect the TomTom and remove any USB devices from your PC, If you use a USB Hub, please disconnect that also.
• Run the RemoveRegEntries tool. You can download it from :-http://tomtom.com/lib/img/cs/S4S/files/RemoveRegEntries_TTGOv1.exe
A Black window will appear briefly then close.
• Make sure that you have got Administrator rights on the PC. Otherwise you may not be allowed to connect new hardware (especially the case when using office computers)
• Reboot your PC
STEP 2 Connect the TomTom
• Make sure the device is fully charged before connecting it to the computer. Ideally a mininum of 4 hours charge.
• Reset the device using a paper clip (see http://www.tomtom.com/6965). When resetting, keep the reset button pushed in for at least 20 seconds, but DO NOT turn the device back on just yet.
• Ensure that your TomTom has power connected to it. There should be a green light on the TomTom unit. If your device came with a Home Charger, please make sure that is plugged in to the TomTom also.
• Connect the TomTom to a USB port on the back of your PC. We strongly suggest that you use a USB 2.0 port and not a USB 1.1 Port. (USB 2.0 ports are faster USB ports, which are standard on all modern PC's, older PC's and some laptops may still use USB 1.1 ports which are slower and can prevent some USB devices from connecting properly).
STEP 3 Switch the TomTom On.
• On your PC, open My Computer
• Now switch the TomTom On while it is connected to the PC with the green light on.
• Look at My Computer, do any disk drives appear as you switch the TomTom On? If so, which drive letter is it?
• Double click on the TomTom disk.
• What files and yellow folders do you see?, please make a note of them and reply back with what files and yellow folders you see. If possible, please provide us with a screenshot showing all the details.
If the device is NOT listed as a 'Removable drive' under 'My Computer' when you switch the TomTom On, try the following:-
STEP 4 Check Device Manager
• Disconnect the TomTom from the computer.
• It is likely that you have a Firewall on your PC, in some cases, Firewalls can prevent USB devices from being recognized by the PC. We suggest configuring your Firewall and security settings to allow all USB devices to connect to your PC. Once you have done this, we suggest trying the steps above again.
• Go to 'Start' and right-click on 'My Computer' and select 'Properties'
• Select the 'Hardware' tab
• Expand 'Disk drives'. If the TomTom device is shown there with a red cross, right-click on it and select 'Enable'
• Check under 'My Computer' to see if the device now shows up as a 'Removable drive'.
We also suggest it is a good idea to try to connect your TomTom to another PC to see if you get the same problem.
Top Tomtom GPS Experts
k24674
Mike Cairns
Mike Cairns
Grand Canyon Tech
Grand Canyon Tech
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
