Konica Minolta bizhub C250 All-In-One Laser Printer Logo
Anonymous Posted on May 07, 2008
Konica c6500 c-2451 error
Just wanted to know if there is a user fix for above error or service call is required
  • Anonymous Mar 18, 2014
    i have a problem from the black dev. c2454 and change to another machine then the error goes to that machine which i took the other developer,my question is how to reset this error c2454?
A
Anonymous
X/fgas;lkt
j]fj'asl
d[lgh
atd
  • SiNnA
    SiNnA Mar 21, 2013
    what is this "X/fgas;lkt j]fj'asl d[lgh atd"
Anonymous
Level 2:
Champion:
  • Expert 214 Answers
  • Posted on May 11, 2008
Anonymous
Expert
Level 2:
Champion:
Answers
214
Questions
0
Helped
192349
Points
268
C-2451 - When the developing motor/Y
(M20) is ON, the maximum
detection value of TCR sensor/Y
(TCRS/Y) is the specified value
and the difference between the
maximum detection value and
the minimum detection value is
over the specified value.
relavant parts:
Printer control board (PRCB)
Developing motor/Y (M20)
TCR sensor/Y (TCRS/Y)
- first check that the motor is turning correctly, clean sensor, check toner pipes, that the toner is rally moving from hopper to developing unit.
2answers
Konica minolta c6000 errors2221
• AC drive board (ACDB)
• Printer control board
(PRCB)
• 1st transfer pressure
release motor (M19)
• 1st transfer HP sensor
(PS15)n
Check the above items first the sensor and the motor the boards $$$$$$$$$$$$$$$
Konica 7020
Did you blow it up, probably not.
Click this link for the everything.
http://www.kmbs.konicaminolta.us/content/support/supporthome.html
  1. Choose the Category "Office Systems"
  2. Choose the model "7020"
  3. Click the error next to the Model dropdown box.
  4. Choose the 1876KB user manual called "User Manual for 7020, 7025, 7030 and 7035"
Or click on this link for the specific manual.
The error codes you seek are not in the manual, you'll have to call Konica to tell you what they are ... call Konica at (860) 683-2222.
Hope this helps. Rate a fixya!
The printer stops working & showed me an error code F-26-1 , How can I repair it ?
Remove the drum cartridge, then remove developer unit, then the charge housing above the drum the remove the drum do not touch it has to be done from the side of drum. once removed then is sensor that has a white cover on it, there is also a clear one white one is in the rear on the left side clean DO NOT USE A VACUUM Cleaner the static electricity will destroy the sensor. Then re install. run all required check . Unless you know what you are doing get a qualified Konica Minolta Technician Has to have Konica Experience You have a legacy Konica machine
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
I have a SCANNER ERROR lamp error message on my Konica Minolta 1380mf page pro pinter, do you know how I can fix it please?
You have a bad drum unit, you will need to replace your drum (dr310) along with the developer (dr310) it's not all that difficult but requires several step to reset the error code, clear the counters and calibrate.
2answers
When I turn it on it starts to ware up and I get an error message engine panic
Can you give me the exact brand and model number of your multi-function printer?
What is the exact error message that it gets?
Any additional information will help us in resolving this issue.
Thank you!
Error code p27
this is a toner density failure code if the service company replaced the developer and did not run the density adjustment it will through this code or it could be an older firmware version you need at least level 16 or it could be a bad toner sensor i would recomend having them come back out to fix it
3answers
Konica is constantly on display
you need to have a firmware upgrade on your copier.
8helpful
3answers
Hp 4250n, 49.4c06 service error message
Hey guys
same error
start
run
cmd
net stop spooler
goto windows explorer
C:\Windows\System32\spool\PRINTERS
delete all print jobs
back to cmd window
net start spooler
hard power reset printer
error gone all working again
Top Konica Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
