SOURCE: Toshiba TN43V71 43 in rear projection
Hello WendyOreo, It sounds like your switching power supply or you High Voltage power supply has malfunctioned. These sections control all power to the TV and can produce the situation you are describing. If you do not have a background in electronics, I would suggest that you have a TV repairperson come over and check your TV out. I say this because there are voltages in a TV set that can kill, so caution is needed. I hope this helps Thank you, Shuttle83
SOURCE: Toshiba 51h85c rear projection screen is red!!
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
SOURCE: Ive got toshiba 40PW13P rear
Howdy,
Well, you didn't ask what you wanted but I think you should try 2 things. One; unplug TV's power cord for 5 minutes, reboot. Two go into the customers menu and try to adjust the convergence.
If these fail call a factory authorized service dealer. Good luck.
SOURCE: Remote control not responding to tv
You need to program the remote to work with the TV. And I hate to point you this way, but I've looked around for the manual on this remote, and can't find it, so, go to the Toshiba website and email Customer service that you have lost your manual for the remote. See if they will email you one. I bet they will.
