Dishwashers Logo
Posted on May 07, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Kenmore ultra wash dishwasher
My dishwasher is filling with water, then draining immediatly after, will continue with the cycle until finished but will of course there is no water in it to wash the dishes with.
What can I do to fix this problem, your answer is greatly appreciated
Thanks,
Ytapia
Anonymous
Level 2:
Scholar:
  • Expert 150 Answers
  • Posted on May 07, 2008
Anonymous
Expert
Level 2:
Scholar:
Answers
150
Questions
Helped
52016
Points
258
Is the water draining out by itself? or is it getting pumped out by the machine? if this is a ge built machine it sounds like the drain solenoid is burned out and the unit is stuck in drain. a bad timer usually makes that happen so you might need the timer and solenoid
My dishwasher fills with water and then 45 second to a minute when the dishwasher is in the washing cycle the sprayer stops spray or washing the dishes and it seem that the water has drained out of washer...
Have you confirmed the water has drained out, or is the water just too cold, so the heater coil is on to get water temp up. What happens if you just leave it alone? Does it continue through the cycle?
1helpful
I have a kenmore dishwasher. While it was in the
hi...
If the cycle doesn't complete, check these....
Water-heating cycle Many dishwashers heat the wash and/or rinse water to a higher temperature, as the cycle calls for it. In these cycles, the dishwasher pauses after it has filled with water, waiting for the water to reach the pre-set temperature. What happens next, depends, as follows:
  • On some units, the pause is timed and the unit continues after the allotted time.
  • On others, the cycle can't continue until the water reaches the higher temperature. If you have this type of dishwasher and the water isn't being heated (say, because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues. When you repair the heating-system problem, the "cycle problem" is fixed too.
Timer Timers don't often fail. But if every other part of the dishwasher seems to be working properly and the timer knob seems to be stuck in one place--doing one function continuously--the timer may be at fault. Dishwasher timers can't be repaired. If yours is defective, replace it.
if still it doesn't fix your problem then see whether any error codes are generated....
F1 Water heating fault, selected temperature not reached within 60 minutes · Incoming water temperature too cool
· Heating element burned out
· Thermostat defective F2 High water level · Plugged/Bad water pump
· Defective water inlet valve F3 Thermistor fault · Open thermistor
· Bad wiring to thermistor F4 Fault with water fill (only on machines with level-controlled fill)
Note: Lights blinking, pump running and controls dead indicates an over fill fault 1. Disconnect the power to the unit
2. Remove the lower access panels and check the tray under the dishwasher (you will probably find it is full of water)
3. Use a towel or a sponge to remove the water
4. There is a float that should stop the operation of the dishwasher and run the pump if water is in this tray. Check this pump to see if it is functional
5. Test the dishwasher
6. If there are no leaks from the dishwasher into the pan, check the drain hose under the sink
7. THE DRAIN HOSE MUST RUN UP TO THE TOP OF THE UNDERSIDE OF THE COUNTERTOP THEN DOWN TO THE DRAIN. (If the hose is not set up like this, water from the sink drain will flow into the dishwasher and overfill the tray
*Faults may vary by model. Use this as a general guide.
i think these details would definitely help you.....thank you...
Smelly dishes from Kenmore Ultra Wash
If you post the model number of your dishwasher plus its approximate age (in years) I can help more.
But the most common cause is a weakening pump motor. On many dishwashers, the wash pump motor is also the drain motor. Replacing that motor / pump assembly will solve the problem. While you are replacing the pump, check the heating element to confirm that it is not shorted out or broken.
For now, add a cap full of bleach to the water _after_ the initial dishwasher fill cycle ends and the wash cycle begins. White vinegar would also work, but this will not fix your problem.
Good Luck!
Kenmore dishwasher, water not going through the jets
when you hear the motor running during the wash cycle, check to see if the washer is actually draining instead of washing. this would indicate a stuck open drain valve. (the same motor/pump that washes the dishes, also drains the unit)
Water fill never stops - never! on Kenmore Model 665-16379301
I had this problem and the drain hose had become disconnected. I had a flooded basement.
3helpful
Water slowly filling cabinet when dishwasher is off.
either
leaking valve - to check, turn water off and see if it still happens
or
if appliance is plumbed in to a spigot on the sink trap, then when you empty sink, some of the water finds its way into the dishwasher via the drain hose. to cure, take the drain hose as high as possible under the sink in a swan neck
Kenmore
Make sure you run water in your sink until it is hot before you start the dishwasher. On the newer dishwashers they will fill and drain until the water is hot enough so it takes longer if it starts with cold water. Normal time for a basic wash could take about 45 min.
Top Dishwashers Experts
Mike Cairns
Mike Cairns
john h
